CT944's Avatar
Cat bypass hardware
Does anyone know what gaskets and nuts/bolts I need to install a cat bypass?
2007 997 TT
1992 500e
Old 12-21-2008, 01:19 PM
Nine9six's Avatar
Try doing a search on "cat bypass"...The same question was recently posted and answered.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-21-2008, 02:31 PM
SteveinTO's Avatar
There's a picture in the Pelican catalog, I think three gaskets involved. Pretty simple. Be prepped for a trip to the hardware store for replacement metric nuts & bolts as you will probably have to dremel several of them into submission.
Old 12-21-2008, 10:28 PM
Band.
You need 3 gaskets, the first three on this page here:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_EXHpip_pg6.htm
and 9bolts, (+nuts and a lock washer) M10 x (at least 32). you might need to adjust the length of the bolts a little bit depending on the thickness of the flange on your bypass pipe.
Have fun!
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 12-21-2008, 11:23 PM
spence88mph's Avatar
m10? m8 isn't it??
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 12-22-2008, 12:35 AM
m110's Avatar
Search "will ferch" and cat fasteners
1988 Carrera Coupe
Old 12-22-2008, 10:18 AM
Band.
Or, type in
catalytic converter gasket
into the search window. Cryptic, I know.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 12-22-2008, 10:31 AM
CT944's Avatar
Have fun!
Thanks Gogar!
2007 997 TT
1992 500e
Old 12-22-2008, 02:23 PM
