Cabriolet Top Elastic Strap Replacement Question
Our cabriolet tops have two elastic-strap sections that run parallel to the roof sides and below the headliner. On my top, the elastic sections have tired out and sagged to the point that they provide no tension. The way I understand it, the elastic portions act to pull the middle-forward top bow correctly back to the rear as the top is folded.
I've looked at replacing the two straps and they appear to be available, but the price is a whole 'nuther matter. Outrageous may best describe it. I've bought 1-inch wide black elastic to sew in to replace the failed elastic sections, but the question I have for cab owners is how much tautness should I build in to the straps when I sew the new sections in? Can anyone describe how it should "feel"? Thanks! Brian |
Maybe someone close to you; DC, Baltimore, Alexandria, etc. with a cab will chime in and you two can meet up and see first hand. If not then maybe some time after first of year I might be up for a little day trip as you are just 3 or so hours away. You could check out mine...then..In the mean time
With my top in the closed/up position the I checked the strap tension at the center bar (one over you head when seated). The strap runs under this bar (between you and the bar) with a small piece of strap sewed to it going over the bar. The strap was taught enough to snap back to the bar when I pulled it toward the seat bottom yet not too tight that pulling it down required effort. With minimal tension the strap would come down about an inch or so. After that more pressure would have been required but the strap going over the bar limited the travel.. Hope this helps and if you do not meet up with someone in your area let me know after the new year and we'll see about trying to meet somewhere so you can see first hand. Gregg S. |
First two are of drivers side the second two of pass side.. if more needed please state what you need as it is mid 60's now don't know what future holds...BRRRRRR.
http://forums.pelicanparts.com/uploa...1230151072.jpg http://forums.pelicanparts.com/uploa...1230151092.jpg http://forums.pelicanparts.com/uploa...1230151116.jpg http://forums.pelicanparts.com/uploa...1230151134.jpg |
Thanks, these dont come with the headliner? Surely for 370 or so dollars you get more than an cut piece of cloth. In the 20's here
Do not know if they come with the headliner (maybe you meant conv. top?) as mine does not have a headliner in it. I inquired about installing the headliner that was installed in later year tops and was told it was waaaayy expensive to retro it to my car.
I just had top replaced when car was in for repaint, or should I say had car repainted while getting top replaced. I do not know if these came with the top or were extra. Total for top replacemeant was $1500. Gregg S. |
If they were replaced with the top I woud take it back there is alot of frayed material there. Do they commonly do that?
Thanks for the follow-up, guys. Hopefully we can share some knowledge here.
These tops should have headliners. Mine does. In 83-911SC cab's pics, it looks like his elastic strap runs completely from the back to the front. On my top, the elastic strap runs from the rear of the top to just before the loop of fabric around the bar. The material continuing to the forward portion of the top from the folding bar is regular nylon. What gives? Brian |
Brian |
As far as headliners I thought they were not installed in cabriolets until after the switch to the 86 year top frame (power/manual roof w/small rear window). I could be wrong..
My straps I would not consider completely elastic like say a underwear waistband or bra strap elastic. Yet it is not non stretching nylon either, kind of a mid ground mix.. My straps go from the front of the top between canvas top and about 8"wide vinyl covered metal plate that is at the front bow area to between the canvas top and the rear vinyl covered plate (also about 8"wide) on the third bow. My top is new, kinda, as it was replaced about a year and a half ago but was sitting in body shop until this past August when I finally got so pissed at the body shop for draggin azz, I picked it up and am still finishing putting it right. This top is the second one they put on as the first was wrong year range..They originally installed the later 86-89 cab top w/small rear window not the original year 83-85 w/larger rear window..made them replace at their cost. Gregg S. |
I believe I have an 84 roof and it has a headliner but I think the straps are not complete and I will need to do some work on them. Anybody else out there that can shed some light on this hope someone took pictures when they put a new top on their roof.
This discusstion is great my kid is bouncing off the walls and we are killing time until we go to a candlelight service at 11 tonight so this is both helpful and making the time pass, thank you all and Merry Christmas.
http://forums.pelicanparts.com/uploa...1230168151.jpg
This is a pic I had in my files of a 83-85 top that clearly shows the straps and headliner. |
Nice pic there. Are we in agreement, then, that the front portion of the 1-inch front-to-back straps are regular nylon material and the elastic portion runs from the loop around the middle hoop to the rear?
Regarding the headliner, PET clearly identifies a headliner for the top beginning with '83. A lot of thought went into these tops -- they are designed to endure north of 140 mph without flapping. Try that, MG and Triumph. ;) Brian |
Yep I agree, Merry Christmas I got to bed about 1:30 this morning and my daughter had me up at 5:15 so what I type might not make any sense sometimes. Jerry
A few years ago I had to remove my worn top to repair (TIG) a crack in the aluminum rear support. I purchased a new top, made my own new headliner, and as well replaced the old elastic supports with new ones I fabricated from material from a local fabric store. I recall laying out the old elastic and determining a point where to sew in new loops for the center bar. I laid the new straps on top of the front and rear frame sections with the roof in the down position. I then pulled the elastics just enough so that it would be rather taunt enough not to have any sag; the tension of the elastic would be less than "half" if you pulled the elastic all the way to its limit, i'd say one third is fair game. Off the top of my head there may have been cotter pins at one end of the straps? and I replaced them with new SS ones. R&R of the cab top is a challenging but a rewarding adventure. Difficulty for the DIY? Frankly I'd rather do a motor drop, however the cab top R&R is less greasy and more interesting. A camera comes in handy. Most importantly you need to insure the gear boxes on each side are correctly set so the "timing" of the top coming down for the front locks is perfect (no twists). I had a printed copy of these procedures as well as a video from the factory. FYI the reason the rear support cracked on my car was because one of the gear box's bolts were loose and the top twisted. Have fun and Merry Xmas. Griff |
I'm getting ready to start driving my cab, so, believe it or not, I just completed replacing the two worn-out elastic sections with new 1" wide elastic from a fabric store.
Once I had sewn the new elastic sections in (as we discussed earlier, you have to pre-tension them before sewing them in), I could fold the top back and watch the horizontal support bar move to the rear and out of the way of the folding top material. Cool! Brian |
Piece of cake!
| All times are GMT -8. The time now is 03:26 AM. |
