NEWFIE 69 911E's Avatar
Rapid battery drain: Alternator bad??
1980 SC
My SC has a developed a rapid battery drain. Battery dies overnight unless disconnected from car. Alternator light not on when engine running.
I read some posts here, and measured current draw to be over 200 milliamp with all electrical turned off. I then pulled each fuse one and one, and the current did not change. There is quite an arc when connecting one of smaller red wires onto the positive battery terminal.
Does this mean that the alternator is bad? Should a local alternator shop with no Porsche experience be able to repair the alternator?
Safe Motoring!
In stable: 1980 911SC Targa RoW Guards Red
1969 911E Coupe
Old 05-07-2009, 04:01 PM
I had the exact same problem in my 83 cab. At one point the only thing left connected was the starter & alternator. I disconnected the starter at the battery feed (which also disconnected the alternator feed), check to make sure the draw was gone. It was gone - so I hooked up the starter only - draw gone. Hooked the alternator back up draw still gone. That was about 5 - 6 months ago & it is still going fine. When I disconnected the starter the stud turned a bit - I thought maybe it was arced to something and turning it broke the contact loose - but that seems a bit far fetched. Sorry I could not give you a definite answer. I think at that time I got a recommendation from this board to replace the alternator.
1983 911 SC Cabriolet
1999 Durango SLT
20001 Intrepid ES
Dave
Old 05-07-2009, 05:57 PM
Hi Dave,
Thanks for your reply. So, in the end, you just disconnected and reconnected the starter and alternator and it has been OK since? Correct?
Seems bizarre, but worth a try I guess! I'll also check th stud on the starter.
1969 911E Coupe
Old 05-07-2009, 06:22 PM
Yes - that is what I did. I did keep a jump box with me at all times for a while after that however. LOL!
1999 Durango SLT
20001 Intrepid ES
Dave
Old 05-07-2009, 06:35 PM
Ok, thanks for the reply. I'll try it this weekend and update. If it works I will get myself a jump box
1969 911E Coupe
Old 05-07-2009, 06:53 PM
Did you ever figure out what was causing your drain?
1999 Durango SLT
20001 Intrepid ES
Dave
Old 05-16-2009, 07:58 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Just my 2 cents...at the next winter storage of my 84, I will remove the alternator, will send it to a shop for a complete OH. I have no problems yet, but this thing is 25 years old...A bit a proactive maintenance is sometime justified.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 05-17-2009, 04:56 AM
New Battery Fixed Starting Problem
Thanks for the reminder.
The problem is now solved
I sorted out the wiring for the Sony CD Player. It was not correct, but making it right did not reduce the current draw; the unit still pulls over 150 mA when off. I think it has something to do with CD ejection; the unit needs some residual power stored to allow the CD to be rejected without powering the unit. Just a theory I have not had time to test yet.
So, I brought the battery to NAPA for testing; It was shot. I installed a new NAPA battery and now the car starts perfectly even when sitting for days and in the cold climate that we are subjected to here in Newfoundland!
1969 911E Coupe
Old 05-19-2009, 07:45 AM
