What's this noise? 1999 996
There's some clunking noise coming from inside the engine bay, I don't know if its internal or external.. then again I don't know what it is period.
There's no loss of power in the car and it drives fine even after accelerating and letting it coast the noise lessens but when the car slows down the noise hightens again and when it idles it slowly drops its RPMs until it dies, ontop of that there's a hole in the radiator hose which i don't know would cause a problem of this clunking but would anyone have an idea of what it may be? It's a 1999 996. Thanks.
Old 12-27-2008, 12:01 PM
Don't worry about it- likely the engine is about to grenade- which is normal for 996.
Old 12-27-2008, 05:16 PM
Oh Haha's Avatar
More info would be helpful and maybe a post over in the 996/Boxter forum would yield better answers.
Do you have good oil pressure at idle and does it increase with RPM's?
Does the noise rise and fall with the RPM's?
How many miles on the car?
It could be as simple as a pulley or as difficult(expensive) as a rod/crank bearing gone.
Pacific Blue
Wayne
The car has 65958 miles on it, the oil pressure stayed the same on the gauge at idle and driving it didn't seem to drop at all. As for the noise, it's more of a hard clunking at low RPMs and a faster lesser noise clunking at higher RPMs.
Old 12-27-2008, 05:38 PM
Oh Haha's Avatar
Well, that's a good sign as it sounds like the oil pressure is good.
Any way you could post a video?
Pacific Blue
Wayne
Old 12-27-2008, 05:40 PM
maxnine11's Avatar
transmission !?!
(let me know if i win)
max
Old 12-27-2008, 05:45 PM
Happiest when Tinkering
gsmith660's Avatar
let off the gas, humm maybe a rod bearing going south?
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 12-27-2008, 07:07 PM
I do have a video although the sound quality is very bad, you'd have to listen closely to hear it but i can't seem to upload it. The normal site i use to upload videos/pictures is taking about 30 minutes, if not failling, to upload a 30 second video..
Old 12-27-2008, 07:20 PM
gsmith660's Avatar
I hope it went up about 10 lbs\1000 rpm if it stayed the same you have an oil pump issue
Old 12-27-2008, 07:23 PM
well the gauge goes from 1-5 on the car and it stayed at 5 the whole time from idle to driving...
Old 12-27-2008, 07:25 PM
gsmith660's Avatar
Pegged high means it is in a failed condition either the sender is bad or it is not grounded good. does it have teflon tape on the sender? That is a bad thing.
Old 12-27-2008, 07:35 PM
Heh i dont know what a teflon tape is >< here's a video though, it's bad quality
http://www.youtube.com/watch?v=iYxtqjzFwG4
Old 12-27-2008, 08:35 PM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
Originally Posted by blackie911 View Post
don't worry about it- likely the engine is about to grenade- which is normal for 996.
lol :d
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 12-27-2008, 09:32 PM
efhughes3's Avatar
I'll point out the obvious here....you posted this on the air-cooled 911 forum. You may want to try the 996-specific forum here, or on Rennlist.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 12-27-2008, 09:36 PM
Oh my - that does sound like it's crushing rocks doesn't it? You might have to consider having it towed to a shop.
1989 Carrera 3.2L in 993 bodywork
Old 12-27-2008, 09:40 PM
oops.. alright guess ill head there, thanks anyways.
Old 12-27-2008, 10:22 PM
slodave's Avatar
What was that fluid dripping right behind the left wheel??
Old 12-27-2008, 10:55 PM
450knotOffice's Avatar
That does sound awful. If I were you I'd flatbed it to a shop.
Old 12-27-2008, 11:39 PM
Now in 993 land ...
aigel's Avatar
Connecting rod bearing. Please let us know what it turned out to be.
Sorry, but clunking at engine speed rarely is good news.
George
81 SC (sold)
Old 12-27-2008, 11:41 PM
sounds like conrod, happened to my 996, time for a rebuild, quite common on the 3.4..
Old 12-28-2008, 12:34 AM
