TDIDog's Avatar
Looking for Pro/Cons ceramic coating
Ceramic coating exhaust and turbo housing as opposed to wrapping. Any & all thoughts. Was thinking of wrapping headers from heat boxes to turbo housing. Objective is mainly under hood heat. thanks for in put.
jack
Old 02-07-2012, 04:08 PM
TDIDog's Avatar
Anybody have any thoughts?
Old 02-07-2012, 09:07 PM
Brando
quattrorunner's Avatar
It works go ahead? Looks purdy. Wrap would possibly retain some moisture against metal where ceramic is not wrapped.
Old 02-07-2012, 09:39 PM
porwolf's Avatar
Just off the top of my head I would say ceramic coating will not provide any heat shielding. Wrapping would, but there is the issue of trapped humidity with corosion potential.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-07-2012, 09:46 PM
TDIDog's Avatar
My headers are stainless, so moisture shouldn't be an issue.
Old 02-07-2012, 10:55 PM
porwolf's Avatar
I hope some experts will chime in. But for heat shielding wrapping should make a big difference, IMHO. And moisture trapping with stainless steel components in the generally hot engine area should be almost nill. Humidity is always driven out of warm or hot areas. Anybody with experience in wrapping exhaust components out there? I do remember having seen it mentioned somewhere else in this tech section. Maybe you want to do a search.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-08-2012, 12:13 AM
TDIDog's Avatar
Was thinking of ceramic coating the turbo & exhaust pipe as well. That is supposed to help too as far as I under stand. Some expert thoughts would be good.
Old 02-08-2012, 12:17 AM
tobluforu's Avatar
If you are going this route then ship parts to swaintech. Lots of people wrap DP's on their cars to reduce heat as long as the dp is stainless. I did on my Saab and it’s pretty remarkable how much it decreases under hood temps, plus it's supposed to decrease spool, but I didn't notice that.
I ceramic coated the old Porsche muffler I had using black Satin (2000 degree) and my main gripe is that it scratched very easily.
Old 02-08-2012, 04:26 AM
Brando
Do a google search. Not much on here but it's cmon and one of the main bennifits is undergo of temps and keeping heat inside the exhaust.
Old 02-08-2012, 07:02 AM
Brando
Do a google search. Not much on here but it's cmon and one of the main bennifits is underhood temps and keeping heat inside the exhaust.
Old 02-08-2012, 07:04 AM
ive done both in the past and there are pros and cons to both.
I like the wrapping because it was cheap, i could do it myself. i hated the wrapping because i drive my cars year round which means dealing with the elements i.e. rain, snow and is a pain in the ass if you get oil on them, they dont look as nice obviously.
I liked the coating because it looks clean, keeps the temp down, dont have to worry about dealing with the elements, oil is still an issue as some coatings will just absorb it (dosent effect anything but, the visual imperfection is there), price is substantially more obviously.
Just because something says that it is stainless steel you might want to check to see if all the welds are as well and what grade it is.
Ryan- Sad day when my 83 911 left me
Old 02-08-2012, 10:45 AM
RETIRED
Joe Bob's Avatar
They scratch easily....good solid pipes is a good thing....the stuff works but is soft against abrasion, impact and other bumps and grinds.
2012 ML350 3.0 Turbo Diesel
Old 02-08-2012, 10:52 AM
AutoBahned
RWebb's Avatar
what you really want are ceramic exhaust ports - ceramic on the headers will provide a much much smaller benefit, esp. on a N/A motor
Old 02-08-2012, 11:10 AM
air cooled Porsches have a tendency to leak oil. When oil gets on the wrap, I've heard of fires starting.
In my Subaru days, many people would ceramic coat the exhaust manifold, uppipe, and exhaust side of the turbo. Those that did reported much faster spool up times. People that ceramic coated their exhausts themselves could pull the pipes out from their grill with their bare hands.
Old 02-08-2012, 11:51 AM
Banned
Wouldn't ceramic coated exhaust ports be a major risk with a turbo - say if the ceramic comes off, and some of it will, it will go right into the impeller wheel . . .
Old 02-08-2012, 12:42 PM
AutoBahned
RWebb's Avatar
sure!
Old 02-08-2012, 01:30 PM
Max Sluiter
Flieger's Avatar
Did 964 Turbos use the ceramic liners? I know the naturally aspirated ones did, or was that the 993?
Old 02-08-2012, 01:34 PM
Andrew Gawers' Dad
CHICKS's Avatar
Wrapped the exhaust on a 1600dp in my old bug. Every time I would work on the thing the wrap would get oil on it, and it would take forever to burn out. It was annoying and pretty embarrassing.
Old 02-08-2012, 01:41 PM
