The 2.4 to 3.2 swap has begun
I dropped the motor and trans today for what is to be the start of a 3.2 swap. I wouldn't attempt this without these forums and I'm sure I'll be bugging everyone with questions. I've read about the past swaps and hopefully everything will go OK.
First stage will be getting the fuel system set up and the electrical. Then I'll pull the transmission off the 2.4 and attach it to the 3.2, I'm not looking forward to notching the trans Then its just bolting it back in and plugging everything up, right.
Another plus is I didn't break anything when I dropped the engine. No torch or BFH was needed.
2000 Boxster S (gone)
1972 911s Targa (sold)
1971 911t coupe roller (sold)
1973 911t coupe / 3.2 (sold)
Gruppe B #057
Old 12-24-2008, 05:04 PM
Zeke's Avatar
Cool. I think you're gonna be looking for bigger rubber.
Old 12-24-2008, 05:10 PM
pozee's Avatar
Good for you!
I can picture you sitting in that chair visualizing the drop before you pulled the trigger.......right?
pozee
Old 12-24-2008, 05:12 PM
midnight911's Avatar
beautiful car...turning into a beast, eh?
take the oil temp and oil pressure senders from the 2.4 and shove them into the 3.2. Most likely the senders on the 3.2 do not work with the gauges you have.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 12-24-2008, 05:39 PM
Looks like you have a couple of projects going. Looking good!
Old 12-24-2008, 05:46 PM
Originally I had planned to put the 3.2 into the gold 71. I bought the 71 roller a couple of years ago. I went to the guys house to pick up some door pockets and ended up with the roller. The 73 was running fine this summer, but was always cold natured and when it turned cold just would not start. So instead of trying to figure out the CIS I figured I might as well put the 3.2 into the 73. It has 21/26 torsions, bilstein shocks/struts, and all new bushings, ect. I bought the 3.2 last year.
The 73 already has the 915 and I believe the fuel tank will work. It also has the dual fuel lines running to the engine compartment. So the 2.4 will probaly go into the 71 with a 911 trans and carbs. But thats the next project.
And yes I was sitting in that chair trying to decied if this was really what I wanted to do.
I sure hope the 3.2 runs. It has good leakdown numbers but that's all I really know about it.
Gruppe B #057
Old 12-24-2008, 07:35 PM
Here is a pic of the motor. It is a 84 euro. I'm going to use some early heat exchangers and backdate the heat.
Gruppe B #057
Old 12-24-2008, 07:43 PM
Roc Doc's Avatar
Have fun. I went from a 2.7 on its' last legs to a 40k mile 85 3.2 and have had a blast ever since. In your lightweight short geared car, it's going to have some real fun potential.
It's not that hard. I ran mine over the first winter with no external cooler, but as soon as spring came, I had to get the Carrera fender cooler and fan.
1976 911S Targa, Carrera bodywork, 3.2l engine.
Old 12-24-2008, 07:54 PM
techweenie's Avatar
You'll have that permagrin soon...
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 12-24-2008, 10:10 PM
E Sully's Avatar
I wish you luck. I'd make sure the cylinder head temp sensor was the newer type and that the flywheel sensors are adjusted before the engine goes in. Also I've read about the engine fuel lines seeping. I've read a few threads about leaks and fires. All are best checked now while the engine is out. It's good to have the engine sheetmetal from the 73 to backdate the heat. The 73.5 fuel tank also has the swirl chamber which is vital for the fuel injection. Older tanks do not work well during cornering with low fuel levels.
Old 12-25-2008, 12:04 PM
Put my order in here for a few parts to get this thing going. DME relay, fuel filter, coil, exhaust nuts and gaskets, 02 sensor, clutch cable, and a few other gaskets and seals. I don't currently have the altitude sensor. I didn't see it listed here and I'm not sure I even need it. I bought a 3.2 fuel pump here used and I'll be running some new fuel lines also.
Not a lot I can do until I get the parts in. I'm cleaning up some engine tin from a 69 and I'll drill the hole for the DME harness. Ill also get the fuel lines run and a bung welded on for the 02 sensor.
Am I missing anything that I need to do while the engine is out?
Gruppe B #057
Old 12-28-2008, 09:05 AM
<insert witty title here>
Christien's Avatar
I'm hoping to do this same project in the coming years. Are you upgrading the brakes at all?
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 12-28-2008, 09:23 AM
I have brakes from a later car, 3 1/2" spacing, originals in the rear. I changed the struts to bilsteins when I went through the car earlier. I don't know if they are really any better than the stock 73 brakes.
This is a street car so I think I'm good with what I have.
Gruppe B #057
Old 12-28-2008, 10:05 AM
Sports Purpose 911 Driver
mjshira's Avatar
NICE. I have done this swap on my old 69. You'll love the difference it makes. I am only about 3 hours away so if you get stuck let me know and I can run over there for a day.
Good luck
JS
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 12-28-2008, 10:15 AM
E Sully's Avatar
You wrote that you were going to use early heat exchangers. The 3.2 has thicker flanges than early ones. You might want to change to shorter exhaust studs or the allen nuts won't tighten up. That or you might need spacers.
Old 12-28-2008, 12:21 PM
Non Compos Mentis
I like this!
Of course, since I have a silver 1973.5 with a 3.2, I'm a bit biased. You're in for a lot of fun with that beast.
Old 12-28-2008, 07:07 PM
rs911t's Avatar
Or use copper exhaust nuts
Greg
Old 12-29-2008, 09:33 AM
Friend of Warren
I might have to drive out to St.L to check things out!
Kurt V
Old 12-29-2008, 10:45 AM
DCinVA's Avatar
Cool project. Perma-grin indeed !!
Dave
2014 Cayman S (Awesome car!)
1991 911 Carerra (Semi Refined fun)
1986 911 Carrerra (Raw fun) sold
2001 Boxster S (Refined fun) sold
Old 12-29-2008, 11:10 AM
E Sully's Avatar
Greg,
I'm curious. What copper exhaust nuts would you replace the allen nuts with that are installed through the holes in the heat exchangers?
Old 12-29-2008, 02:33 PM
