mnmasotto's Avatar
Does a quiet 3.6 conv. exhaust exist??
I want to put a 993 3.6 motor in my 1987 Carrera. The major hold up is a concern about how loud the car will be. All the 3.6 conversions I have heard thus far are too loud. Is there a exhaust system with heat that I can use which will give me reasonable db level and not be too restrictive. A stock 993 car with stock exhaust is great! I can even live with something loader. I currently have SSI's with a two in one out MK muffler on my 3.2. This is very livable but I don't want anything any louder. Please help.
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 12-31-2008, 10:26 AM
skinnerd's Avatar
Have M&K build you one for the 3.6............
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 12-31-2008, 10:47 AM
What's the problem with using your existing muffler?
Tinker
Old 12-31-2008, 11:06 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I use a Magnaflow X-style 2-in 2-out and 993 heat exchangers. There is a glass pack on each of the outputs of the X-flow muffler. It sounds descent and not too loud or agressive.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 12-31-2008, 11:22 AM
mnmasotto's Avatar
3.6 transplant
I have seen a car with 3.6L transplant, stock 993 heat exchangers and a M&K muffler moddified to fit these headers. The muffler is a 2 in 1 out design. I asked Ben why he does not make a 2 in 2 out to fit the 993 HE's. He says "The 2 in 1 out is too loud enough" I agree with Ben. It is definitly louder than my similarly set up 3.2L with a M&K 2 in 1 out.
2007 997 GT3 - SOLD
Old 12-31-2008, 11:33 AM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
fwiw, My 3.6 w/ B&B exhaust w/ heat is quite a bit more quiet than my 3.2 w/ SSI & MK 2x2.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 12-31-2008, 11:43 AM
QSC or s-car-go headers with one of my sport mufflers designed for them are fairly quiet. I think the new 3.6 mufflers M&K is capable of now would fit the bill for you. but make sure you have bischoff HE to start with. I am using them on my turbo engine as well. Mark Give me a call Friday we can talk about options
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-31-2008, 03:59 PM
Zeke's Avatar
Now's a time when I wish I had some money. Mark's engine from the top to the bottom is probably one of the best motors in any of our cars. I can't imagine taking it out, but....
Old 12-31-2008, 04:14 PM
FWIW,....We have a special GHL header/heat exchanger made specifically for us to accept any factory dual-inlet muffler of your choice.
IMHO, thats the quietest route for a 3.6.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-31-2008, 06:50 PM
jevvy's Avatar
There was a dude on here that fitted the full 993 muffler setup on his early car conversion. I think he moved the oil tank to make room for the side mufflers and he seemed overall happy with the results - might be worth a search.
I have an M&K 2 in 1 out with 993 HE on my conversion and its pretty loud - I have also had the Magnaflow box similar to ischmitz mentions above and tbh there isn't a lot of difference between them.
I could just scrape into 105 db track days in the UK with both mufflers.
'89 3.2/3.6 coupe
Old 01-02-2009, 04:08 AM
Keep in mind that the gen5 993 mufflers are much quieter then your gen3
Ben
89 944,85.5 944
914-6werkshop.com
Old 01-02-2009, 05:12 AM
shahram's Avatar
I would go with a stock 993 HE, cat and muffler set up. Of course the oil tank needs to be relocated to the front side of the rear right fender.
Old 01-02-2009, 05:23 AM
jevvy's Avatar
....and there's your dude
'89 3.2/3.6 coupe
Old 01-03-2009, 02:21 AM
shahram's Avatar
Hey jevvy, I posted the pic to help you out!
Just kidding! Happy new year to London.
Old 01-03-2009, 02:45 AM
buttjoint's Avatar
How are you going to smog a 87 with the 3.6 ?
Old 01-03-2009, 07:09 AM
Bill Verburg's Avatar
Good luck getting a bumper to fit over that. Even the turbos have issues when tying to do that sort of exhaust setup though it can be done, it leaves the exhaust hanging awful low
The quitest I've heard is a Full Fabspeed header and muffler setup, note this is not the same as the Fabspeed B&B header setup which is just a Flowmaster cross flow muffler.
To get quiet you need as large a volume as possible, modifing the inlet points of a stock bannana is probably the best way to do it. Steve has some pics at his site.
Bill Verburg
Old 01-03-2009, 07:19 AM
Kevin Stewart's Avatar
I have a full B&B system dual in dual out 3.6 conversion i had the 4 inch tail pipes, after reading a post by Jack O I reduced the tail pipes to 2 or 2.5 cant remember but can look if you want, no more setting car alarms off as i drive down the street sounds like a quiet indy car now, Kevin
Old 01-03-2009, 09:03 AM
shahram's Avatar
No problem Bill,
here you go:
- OEM 993 HEs, cat and muffler:
- With a set of headers, cross pipes and 993 modified mufflers:
- With cat-bypass and 993 OEM HEs and Mufflers:
- And currently working on a set of OEM 993 mufflers + diverters, so can make them quite whenever you want to
Sports Purpose 911 Driver
mjshira's Avatar
yes, I have it. do a search (I've lost the pics, sorry) Timmon's headers with heat, two magnaflow 16inch single mufflers joined to look like one large muffler. no restriction, good sound under load, quiet the rest of the time.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 01-03-2009, 09:15 AM
No problem Bill,
here you go:
Amazing, it was bad enough on a turbo boy. But as I said, the're hanging low
Bill Verburg
Old 01-03-2009, 10:34 AM
