-   -   74 RSR flares don't match? (http://forums.pelicanparts.com/porsche-911-technical-forum/449233-74-rsr-flares-dont-match.html)
ted 01-02-2009 09:13 AM
Why?
911 Turbo flares have a perfect shape but these....
ted 01-02-2009 09:14 AM
Photo, see front and rear arches are not the same?
http://forums.pelicanparts.com/uploa...1230916483.jpg
http://forums.pelicanparts.com/uploa...1230916492.jpg
kycarguy 935 01-02-2009 09:55 AM
74 RSR flares have a rear vent. That is the part that is sticking out on the orange car on the fender close to the door.
ted 01-02-2009 10:31 AM
got it but
Just comparing arches.
Appears most RSRs are very different front to rear and altogether different from factory Iroc/turbo flares too.
My RSR is ready to paint so maybe leave them mismatched too?
I can't tell if the Wally car arches match the white factory car?
http://forums.pelicanparts.com/uploa...1230920023.jpg
double stitch on rear flare displays extra arch width.:)
http://forums.pelicanparts.com/uploa...1230920053.jpg
http://forums.pelicanparts.com/uploa...1230920815.jpg
Iroc flares match.:cool:
http://forums.pelicanparts.com/uploa...1230920438.jpg
This is nice too.
http://forums.pelicanparts.com/uploa...1230920753.jpg
kycarguy 935 01-02-2009 11:23 AM
I think the Wally car arches match the white factory car. It just shows up more in the white car because of the shadow and the shadow against the white car.
zithlord 01-02-2009 01:14 PM
74 RSR had vents front and rear. US Iroc did not, they had the same flares as the 74RS.
John
kycarguy 935 01-02-2009 01:45 PM
Ted did your question get answered?
eimkeith 01-02-2009 02:20 PM
Ted, it looks like that front arch might be a residual carry-over from the previous (74 3.0RS, 73RSR, etc) front flare shape. If so, it stands to reason that the rear flare shape could be a one-off arch (that made it into the later 930 arch), does it not?
I'd leave them mismatched, it reeks of Porsche that way.
zithlord 01-02-2009 02:26 PM
OK, I will refrace, the green car has the wrong combo, 74RS/Iroc front flare and the 74RSR rear flare. But if you want to miss match, its a free world!
John
barney911rs 01-02-2009 04:11 PM
Could be a very dumb statement/question, but never stopped me before. :D Wouldn't you need a larger arch in the front to allow room for the bigger wheels and tires to clear when at full lock. The rears just roll in one direction, so you can tuck the body work in a little tighter.
rattlsnak 01-02-2009 04:44 PM
Dont know the answer, but seeing the Gelb Green one (second pic) makes me want to build another one.
ted 01-02-2009 11:19 PM
quoting Dave at TRE
"The RSR always had weird wheel well openings. They never matched at the factory. Its almost like the front well opening was elongated slightly upward when you look at the car from the side and of course a rounded edge
If you get the symmetry side to side for rear and then for front/ its probably the best you can hope for."
Fwiw Imho many top RSR cars in the US look just like Dave discribed.
Perhaps the difference in flares shows the speed of evolution as the 911 quickly progressed from short hood RSR to turbo 934/935?
Do the wider 15" rear flares show more arch contrast than the 13" flares?
The wider 15" RSR rear flares are more IMSA, like a Dekon Monza.
some very good common sense replies, thank you, not sure how I'll leave it...
I like turbo flares that match, RSR flares are just different. ;)
one for slate grey fans.
http://forums.pelicanparts.com/uploa...1230966700.jpg
http://forums.pelicanparts.com/uploa...1230966727.jpg
Ferrino 08-07-2015 03:05 PM
An old thread but I don't see anyone explain *why* the front flares were so weird looking. My searching suggests that it was due to the increased +ve scrub radius on those wide front flares, which cause tire clearance issues at extreme steering angles.
