-   -   where is your msd box? (http://forums.pelicanparts.com/porsche-911-technical-forum/449253-where-your-msd-box.html)
mack6820 01-02-2009 11:27 AM
Hey guys. Im installing the msd ignition box setup and Im not sure where or how to mount it. I took the cd box out and the msd box is like twice the size of the cd box. SHould I just drill into the metal bracket? Should the wiring harness be on top or bottom of the box? Id love to see some pics..
Thanks in advance and Happy New Year!
vash 01-02-2009 11:36 AM
mine is in the stock position...wire harness faces down. i am at work, so if nobody else posts up a pic, i can get you one tonight.
mack6820 01-02-2009 11:39 AM
were you able to mount all 4 bolts? Also what do I do with the old plug? Do I just stash them away somewhere?
vash 01-02-2009 11:57 AM
yea, i mounted all four corners. those rubber threaded bumper things are really nice. makes taking things on and off really easy.
mack6820 01-02-2009 11:59 AM
I have the MSD box 6AL. Its alot bigger and there is no way it will mount onto the bracket.
vash 01-02-2009 12:07 PM
i have the 6AL also. i guess i have to post up some pics later.
mack6820 01-02-2009 12:11 PM
please do. Thanks so much. Does anyone else have pics? A search for MSD doesnt work.
vash 01-02-2009 12:18 PM
hahaha. called my wife to see if she could snap a pic..i could feel her eyes rolling over the phone.
i will get them tonight.
mack6820 01-02-2009 12:20 PM
haha, sorry if you get a bad tv dinner tonight Vash
mack6820 01-02-2009 12:46 PM
Does the regulator mounted next to the cd box have to be trashed also?
mack6820 01-02-2009 01:27 PM
ok, next question. Where did you install your power wires? DO I have to go under the car to locate the starter cable?
Walter_Middie 01-02-2009 01:28 PM
Here's a picture of my installation. The MSD box is larger than the stock CD box, but it can be mounted in the same location. The upper forward corner hits the wheel well, but if you space it out just 3/4 of an inch, it will clear. Vash used rubber spacers, I just used a 3/4 inch hunk of plywood painted black. It has held up just fine for about 10 years.
http://forums.pelicanparts.com/uploa...1230931731.jpg
I got power from the top engine compartment fuse as shown. Since this picture, I have run the wire behind the electrical panel for a cleaner installation.
mack6820 01-02-2009 01:35 PM
Thanks Walter. I was able to mount the box sideways. I removed the regulator. I'm pretty sure I have the alternater with the built in regulator. Atleast Im crossing my fingers. Now as for the power wire, the book says it has to be a constant hot wire. None of those fuses are constant hot. Does it matter if its constant hot or not?
peters911s 01-02-2009 01:42 PM
Hope this helps...
got this from a fellow pelican...wanted to pay it forward.http://forums.pelicanparts.com/uploa...1230932521.jpg
RoninLB 01-02-2009 01:42 PM
I mounted mine where it would get max air flow. A good place is in front of the engine. MSDs get hot.
not my setup
http://forums.pelicanparts.com/uploa...1230932555.jpg
Walter_Middie 01-02-2009 01:47 PM
Mack6820,
If none of the engine compartment fuses are hot, I'd go for the starter next.
mack6820 01-02-2009 01:49 PM
Thats a nice setup Ronin but I dont have carbs. I have the spaghetti of a CIS.
barney911rs 01-02-2009 02:02 PM
Not a street solution, but on my race car, I mounted it on the other side (inside) of the firewall from where Ronnin has it. I wanted to keep the electronics away from the heat. Works great for me.
RoninLB 01-02-2009 02:13 PM
some guys around here add a section to the electric panel that extends it so it'll mount the MSD. It's not hidden behind the panel cover.
I built a seperate panel that sits between the electric panel and front cabin bulkhead, but I don't think you'll have room for that?
I'd try to find a pic of the MSD mounted on the extended elec panel so the box is able to see some cooling.
mack6820 01-02-2009 02:13 PM
now my pain is to figure out how to route the power wire to the starter.
