-   -   Speed sensor damage? (http://forums.pelicanparts.com/porsche-911-technical-forum/449453-speed-sensor-damage.html)
Dixie 01-03-2009 01:29 PM
Should this speed sensor be replaced? It still works.... I noticed it has a slight groove worn in it when I was replacing the leaking rear seal mentioned in this thread.
http://forums.pelicanparts.com/uploa...1231018114.jpg
carrera turbo 01-03-2009 01:44 PM
i wouldnt worry about it, it looks very slight and not through the outer shell or cap.
just my thoughts
thanks ed
pozee 01-03-2009 03:08 PM
If you have easy access to them already, I would definitely replace. Are those metal shavings? Wonder how that happened? Was the bracket loose?
Dixie 01-03-2009 03:26 PM
I think it happened because I obviously didn't set the clearance correctly. Since I had the engine out, I reset the clearance at .008 mm. Even though I used BMW E30 sensors, they're still pretty freakin' expensive. (What isn't on a 911?)
dshepp806 01-03-2009 06:02 PM
Get some fresh parts and "put it to bed". She wants you to do this...(?) She "needs" you to do this....this time with absolute perfect spec clearance.
Best,
Doyle
p930man 01-06-2009 01:33 PM
I put a slight dent in mine when I mounted up my 915 trans to the studs on my new 3.2
engine. Put the engine back in and got know fire. Meter her out, it should be around 950-
1020 ohms. Mine read open. Now I have to drop the engine. Replace her if you can easily
otherwise I'd run her.
88911coupe 01-06-2009 01:48 PM
Are you saying you think the damage happened b/c you set the spacing .008mm vs. .8 mm?
