Southern Class & Sass
Dixie's Avatar
Speed sensor damage?
Should this speed sensor be replaced? It still works.... I noticed it has a slight groove worn in it when I was replacing the leaking rear seal mentioned in this thread.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 01-03-2009, 01:29 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
i wouldnt worry about it, it looks very slight and not through the outer shell or cap.
just my thoughts
thanks ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 01-03-2009, 01:44 PM
pozee's Avatar
If you have easy access to them already, I would definitely replace. Are those metal shavings? Wonder how that happened? Was the bracket loose?
pozee
Old 01-03-2009, 03:08 PM
Dixie's Avatar
I think it happened because I obviously didn't set the clearance correctly. Since I had the engine out, I reset the clearance at .008 mm. Even though I used BMW E30 sensors, they're still pretty freakin' expensive. (What isn't on a 911?)
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 01-03-2009, 03:26 PM
dshepp806's Avatar
Get some fresh parts and "put it to bed". She wants you to do this...(?) She "needs" you to do this....this time with absolute perfect spec clearance.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-03-2009, 06:02 PM
I put a slight dent in mine when I mounted up my 915 trans to the studs on my new 3.2
engine. Put the engine back in and got know fire. Meter her out, it should be around 950-
1020 ohms. Mine read open. Now I have to drop the engine. Replace her if you can easily
otherwise I'd run her.
Old 01-06-2009, 01:33 PM
Are you saying you think the damage happened b/c you set the spacing .008mm vs. .8 mm?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 01-06-2009, 01:48 PM
