The Hurky Jerky's
F!!!!
I have been chasing this for a while and read a lot of posts..Cory for one (tippy) and know there is an answer but son of a B!!! I am not liking this - idle's a little rough, not bad Power to boot...she goes like a raped ape but 2500 rpm slightly on gas cruise is horrid! so far, new plugs, cap, rotor, wires, valve adjust, CO multiple times on a machine (after each change) compression and leak down looked fair to good, injectors all fire but have not check spray pattern, new chip, MAF (remove AFM) another chip...back to stock AFM and stock chip, cat delete, new muffler, check and adjust idle stabilizer, IDK probably a few other things....checked micro switch, used break out box on DME checked all inputs..... I WILL GET THIS!! so this is more of a venting thread... Think I will change the injectors next!!....maybe a vacuum leak though I have looked! - fuel filter is relatively new, fuel pump and DME relay are new have not checked fuel pressure... anyhow its a warm day so the car is clean....done for now - maybe
Ed M 86' Coupe |
Hi Ed,
I'd love to help you, however I would need a lot more detailed information about how the car runs at light throttle and cruise than simply "horrid",... ![]() Barring that, I'd have the injectors professionally tested and cleaned, look for any small vacuum leaks as that's common on these cars with some miles on them, and clean the grounds on the left side intake manifold.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks Steve...
Horrid: seems to come on and off throttle abruptly causing a jerking motion rather subtle sometimes and rather violent others. Seems worse on a slight down hill where I am just on the gas enough so it is not using compression to slow down the car...rolling. coming off throttle I get back fires on a semi regular basis maybe "missing" at cruise its tough for me to know since I dont have any other 911 driving experience to compare to
Ed M 86' Coupe |
Sounds like timing too advanced or a vacuum leak.
broken rubber clutch hub? unplug O2 sensor and see if it's better. any dead or near dead holes at idle? a lower intake gasket being sucked inward is common, killing a cyl at idle.
Subscribed, my parents 78 SC also has (what sounds like) this exact problem. So far no luck diagnosing after new injectors, distributor rebuild, plugs/wires etc.
Noah 79 SC minerva blue metallic Eureka CA / Boulder CO Physics is like sex, yes there are some practical applications, but that's not why we do it. |
Lean condition at idle. Does it lurch when idling along in first? Most likely a vacuum leak somewhere. Use carb cleaner and spray it at the base of each intake runner while at idle...it may not change the idle is the cylinder is "dead" but you should see the cleaner disappear and smell it in the exhaust. If no leak is found at the runners, start spraying it at each vacuum line....you'll
Soon either find a leak or move on to the next set of options.
1986 3.2 Carrera |
Chain fence eating turbo
No way Ed?!?! You're a victim too?
I am at the point of pulling all of the Motronics off mine and going MegaSquirt. When mine starts surging, I see the AFR's go very lean and then back to somewhat normal over and over again - maybe what your's is doing too. PM me, I'd love to talk about this with you. "ischmitz" and "scarcellar" have been knowledgeable and patient with me and my questions. |
Rescuer of old cars
To me it feels like the a over-sensitive fuel cutoff (like many Motronic systems do under compression) causing the drivetrain to rock badly. I'm wondering if I need new engine mounts. In any case, subbed. Quote:
I don't know how possible something like this might be, give that (unlike the Jetta) the intake is all mounted to the engine on the Porsches. (Or is it? I need to look into that as well.)
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 Last edited by Arne2; 02-05-2012 at 08:31 PM.. |
All of a sudden, it got really bad to the point it was jerking, then started cutting out, then got so bad it started backfiring. For another data point for these cars; since I installed the Innovate Motorsports AFR wideband, I've been watching AFR's very intently. One thing I noticed on mine is when you start the car cold and it is running in the 12's range for AFR's, it will briefly go up to 18.XX:1 AFR's and stumble and cough and then go back to say 12.XX:1 AFR's and run fine. If it is an intake leak from your experience, it should never fluctuate back to a normal AFR IMO - it should always stay lean......at least in my cars since it does not have an oxygen sensor for feedback. Something goes wonky in these cars.....and I've yet to figure it out........ GL Ed, I feel fer ya
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
all good reading....all good!
Cory, I remember when mine did it...I got on the throttle on an onramp and heard a strange noise..a noise I have never heard before, and it sputtered a couple times...since then it has done this.... I changed out the AFM and it was exactly the same intake leak is high suspect John's comments have me wondering though...can you elaborate on the clutch and the lower intake gasket since mine was all of the sudden and made a noise, the clutch thought seems plausible...but how can a clutch effect running - give the the dumbed down version
Ed M 86' Coupe |
for your viewing pleasure.....
my 86 next to a friends new GTS Saturday.... ![]() the 993 is another friend, he also brought his 996 Turbo - sucks to be him huh?
Ed M 86' Coupe |
When mine stutters and hesitates, it is running very lean at that point. Goose the throttle, AFR's come down to 12-14 and all is good.
BTW new motor and trans mounts (club sports)
and the O2 sensor plugged or un-plugged = same smell (an old saying for "same thing")
Ed M 86' Coupe |
76 911S Targa
Ed,
In the old days this jerking was caused by a carburetor adjusted too lean. Simply richening the mixture screw would make it stop. For this reason, I suspect an air leak giving you a lean mixture with your fuel injection. Possibly, as suggested above, it is intermittent. Al
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Porsche Addict
Similar issues in the 84. Ended up being a faulty ICV - tried cleaning, then bought new - which helped a bit. But ultimate solution was replacing the AFM with a rebuilt unit (the wiper track on the AFM was worn).
Good luck!
_____________ 1985.1 944 NA Past: 84 RoW Coupe, 86 Carrera, 95 993, 80 SC, 73.5 T |
Rick, I replaced the AFM with a MAF unit - there was no change. back to stock now, has anyone changed the idle possition switch? Also there is a detailed section in the Bently on setting these things up with a "gap" to the micro switch - the process is a little confusing (like the first clutch adjustment was) but I wounder if there is something to that series of adjustments too...linkage and stuff....
if nothing else its frustrating as all get up - having fun, wish you were here..... LOL
Ed M 86' Coupe |
I really think there is an inherent bug in the Motronics that produces this phenomena. I've replaced EVERY part in my Motronics except the cylinder head temp sensor to no avail. It specs out everytime to the manual so I didn't replace it.
You have to have 3 hands to do the manual's method.....
