There is an inexorable trend (a fad?) to stuff the biggest torsion bars possible under one's car. But, I've driven "tight street" (22/27 torsion bars) and nearly stock 911's side by side to test them on some of our windy & bumpy roads nearby. I have a very twisty and very bumpy road near my house. It is narrow and goes up a hill leading out of town.
Neither car had metal joints (monoballs or purely metal Heims). I drove them back to back and it takes only about 7 minutes to get to that road from my house. This means I could drive a car on that road, then quickly check out the other car, without having to make comparisons to a distant memory. I found that the softer suspended car (my old '75S) was not only more comfy, it was also faster on this road. The Boxster S I used to have was much, much faster than either. This '73 is the car that had the 22/27 combo. So, I am now going to go "backwards" on the front to a 21 mm bar. Here is a map and some pics of my test track: http://forums.pelicanparts.com/uploa...1232325731.jpg |
The nicest torsion bars I've seen are the hollow ones that are plugged and plated by Chuck M. (Elephant Racing). I think they are made by or for SRP.
http://forums.pelicanparts.com/uploa...1232326120.jpg http://forums.pelicanparts.com/uploa...1232498609.jpg |
Aside from the variables you noted, shocks/struts matter, a lot. BTW, a well-driven Boxster or Cayman can be a fearsomely quick auto-cross car. Of course, with 20+ years of development and a mid-engine, some might argue it damn well ought to be.;) |
I found that the stiffer suspension was just miserable around here with the poor roads and endless speed-bumps. I am in the process of converting back to 26mm/19mm from 28mm/21mm. I also found the Bilstein Sports to be intolerable for our streets so it is back to HD's.
It did have one benefit. My wife refused to drive it. :D As to the goop on the front camber plate, it looks more like sound deadening material. I wonder if it is there to reduce noise and vibration from the front suspension. |
I wouldn't think so. Stock, the car's strut is mounted inthe rubber center of the camber plate. That will isolate NVH much much more than a layer of goop.
Bob - yup -- this is "mainly" a street rod. It is, of course, capable of venturing into a parking lot AutoX or onto a track.... |
OK, I am not going to post pics (or text) that are duplicates of what is already out there...
This is a particularly well done thread on this operation and the rear suspension too: http://forums.pelicanparts.com/showthread.php?s=&threadid=199565&highlight=polybr onze And here is one pic showing the denouement: http://forums.pelicanparts.com/uploa...1232416684.jpg |
Various threads have discussed "stiction" -- the stationary friction or sticking encountered when two parts are at rest, as opposed to sliding friction.
I have an interllectual unerstandin' of the issue, having gone to an engineering school as an undergrad. But, I never had a real world "hurts my back" type FEEL for the nasty stiction of the polygraphite bushings until now: http://forums.pelicanparts.com/uploa...1232416866.jpg It was simple to take the A-arms off (tho I have a nagging suspicion that it might be tricky to put them back on and get the ball joint shaft inserted correctly into the female strut.) But just taking off the front & rear mounts was a real mother -- now I have felt stiction in my own hands (and back muscles). The thing can be rotated with (at a guess) 100 ft-lbs. of torque once you get it going. But it must be 2x or 3x that to get it moving in the first place. And rotation with a pull was the only way to get the thing off of the arm. |
And that is unloaded. Torque goes up when the corner weight is resting on the bushing! Or twice the corner weight as when loaded up in a hard turn! In operation both bushings are twisting simultaneously, twice the torque! That is why polygraphite bushings ride so harsh. |
"While in there," I pulled the upper port cover off the steering rack.
It looks fine to me. The grease was not at all caked or "clayey" and not too liquid either. I put a bit more grease in, put the pressure block and spring back and put the cover back on. http://forums.pelicanparts.com/uploa...1232672780.jpg The pressure block looked fine too - I guess I should have used my fingernail to make sure there was no groove, but I didn't. [see: http://forums.pelicanparts.com/showthread.php?t=224112&highlight=steering+rack+re build&page=2 and look at post #39 by KTL and the pic on the first page] |
Ugh!
http://forums.pelicanparts.com/uploa...1232830064.jpg This rust could not be seen while the front A-arm mounts are installed. Something else to check over periodically I guess. Another problem is the poor design of these things. The red ellipses show the 4 areas where the welded on reinforcement shell has gaps in it. These allow water intrusion deep into the area which fades into a crevice to either side. I cannot think of a better design to promote rust. |
Is this car gonna be ready late April? ;)
I am in agreement on t-bars and hard joints. My car is going to 19/26 turbo bars, Elephant PB bushings and rubber everywhere else. Everyone also forgets about sway bars - they significantly affect ride quality, too. |
HA! May well take that long. Turns out Wurth self-etch primer needs 65 oF for application. I have some light bulbs under the car now, trying to warm it up.
I spent a day grind at the rust (got rust, undercoating & grunge all over my face & hair - washed that out ok then went drinkin' -- got to the restaurant and this Morrocan place had warm wet towels so I wiped my hands & face... turned the towel black. I had bits of undercoating & etc. all thru my beard....). Finally washed all of that out & then used rust reducer (aka, converter, aka neutralizer) on the remaining areas. Next, will prime and then top coat with a satin black oil based enamel. I don't have any epoxy type paints and it seems crazy to buy a bunch of that stuff when I have half-pint of the XO-Rust stuff sitting there waiting for me to use it up. Then, I'll have shot at undercoating in the cold... Waiting for the Pelican parts shipment now... Yeh - the sway bars will be addressed in phase 3.... |
I appreciate the danger of While You're In There - itis, but I'm glad I decided to pull the pedal cluster....
http://forums.pelicanparts.com/uploa...1233278324.jpg As Zippy the Pinhead put it "YOW!" |
my plan is to wire brush it - scrub it clean w/ soap & water
and then use a rust converter treatment Kenikh & others: any thoughts on that? I don't see the point is spending a lot of money for an epoxy paint like POR-15 for this application. |
I'd scrub/sand it down, then use a rust converting primer - it's only $10 a can. You let it sit overnight, then you can paint over it with POR-15, which is again, only about $10 in a spray can. $25 is cheap insurance against future mishaps.
Glad you found that! Take care of that now. I just had to replace that whole panel on mine (plus the whole floor, both door jams, all rockers..inner and outer, suspension pan, fenders and other assorted parts) :)
who carries the spray cans of POR-15?
Autozone? Knecht's? Napa? CarQuip? that's what we have here... |
I think you have to order it.
| All times are GMT -8. The time now is 10:31 PM. |
