-   -   Yet Another Boring Rgruppe Car – Part II, Suspension (http://forums.pelicanparts.com/porsche-911-technical-forum/450565-yet-another-boring-rgruppe-car-part-ii-suspension.html)
kenikh 01-30-2009 02:25 PM
I can buy it at the local paint supply store, right down the street from work (Wesco). Lemme know if you need a hand.
RWebb 01-30-2009 02:45 PM
Thanks. Maybe I'll start a "spot" rust treatment thread...
RWebb 01-31-2009 10:04 PM
BTW - this is what the pedal cluster looked like before - hard to see anything wrong with it...
http://forums.pelicanparts.com/uploa...1233468227.jpg
J P Stein 02-01-2009 02:22 AM
For stuff like that I use Rust Mort then a coat of etch primer, RM makes a good one (both from an auto paint store), topcoat of your choice.
I would not use Por15 on a wheelbarrow.
al lkosmal 02-01-2009 05:55 AM
I wire brushed mine and applied POR-15. Worked very well.
egertk 02-01-2009 03:13 PM
I've got my POR-15 and metal ready before through NAPA. Might check them out.
RWebb 02-01-2009 05:08 PM
Thx - I finally found some - $42/Qt. No thanks to that. I am using a Rustoleum primer and paint. That should last 30 years, at which point it is someone else's problem...
mjshira 02-01-2009 05:47 PM
I've found it at PepBoy's before.
Great thread, now, I thought only young guys 'street raced'? ;-)
RWebb 02-01-2009 07:43 PM
oh no - don't get the wrong idea - I obey all speed limits and traffic laws at every moment.
mjshira 02-01-2009 07:55 PM
What would Shultz say? 'I know NOTHING'!
burgermeister 02-02-2009 03:06 AM
Our local independent auto parts store has a competitor's product (forgot what it's called) in 4 or 8 oz wee cans for $10. Perfect for such jobs, since the whole can has a tendency to turn into a solid glob of hardened goo once it's been opened....
RWebb 02-02-2009 02:12 PM
OK, any thoughts on why somebody would weld this thing on there?
http://forums.pelicanparts.com/uploa...1233612731.jpg
DW SD 02-02-2009 02:29 PM
WOW, I'd just try to source a nice clean one, rather than fixing that thing.
Looks like someone welded a stop on there, but it is just speculation. Or maybe it was for the brake switch?
Doug
Zeke 02-02-2009 02:35 PM
The person who did that might have thought it was a way too adjust the brake pedal lower for heel and toe. Instead, it looks to me like he was reducing overall pedal travel. That could have had some serious ramifications under stress.
RWebb 05-26-2010 07:02 PM
Pedal Cluster – Major Parts
info from Pelican catalog
no shaft listed for ‘73
911-423-027-01 - Pedal Shaft, 1974
911-423-027-03 – “ 1975
911-423-027-04 – “ 1976
930-423-027-01 -- “ 1977-86
from PET pgm version () =part ID. – for ??
(21) 911-423-219-03 – spacer
(22) 911-423-065-02 - bearing bracket (bottom “cup”) –
(25) 901-423-250-02 – reverse lever, front (has 3 connections on it)
(28) 901-423-035-00 – bearing tube
(33) 911-423-027-01 – clutch pedal shaft (1972-on)
(35) 901-423-312-00 – clutch pedal, lower part
(40) 901-423-053-02 – brake pedal
(42) 901-423-531-00 – return spring
(43) 901-423-507-02 – intermediate piece
TRE says - Clutch actuation shaft is different between a 70-71 and 72-75; otherwise all is same
RWebb 05-26-2010 07:03 PM
http://forums.pelicanparts.com/uploa...1274925788.jpg
36 parts on this diagram
RWebb 05-26-2010 07:08 PM
http://forums.pelicanparts.com/uploa...1274926054.jpg
Take a look at the roll pin and the rusty bottom of the pedal cluster cup. NONE of this could be seen in situ. I had gotten down in the footwell with a flashlight after taking the floorboard out to inspect it and could not see any of this.
RWebb 05-26-2010 07:10 PM
Note that these brake hoses are not well sealed - this is something else one should check periodically.
http://forums.pelicanparts.com/uploa...1274926236.jpg
RWebb 05-26-2010 07:13 PM
The best way to check is to put a trouble light up under the F suspension pan. (I did this while rebuilding the F susp., which is why the pedal cluster stuff is oddly in this thread & not the interior thread). Then darken the footwell area and the light leaks show your water leak areas. Note the circled area and compare with the last pic.
http://forums.pelicanparts.com/uploa...1274926432.jpg
RWebb 05-26-2010 07:17 PM
Here is a pic of what the apparently nice & clean footwell area looked like after I removed the pedal cluster.
http://forums.pelicanparts.com/uploa...1274926581.jpg
So, folks, be SURE to remove the pedal cluster every few years and check it out -- inspection with the piece in situ is not adequate.
Here is a pic of one unfortunate person's pedal cluster area:
http://forums.pelicanparts.com/uploa...1274929579.jpg
Don't let that happen to you. Pull it out and check.
I treated mine with rust reducer and then with a Rustoleum primer on top of that.
http://forums.pelicanparts.com/uploa...1274926629.jpg
Then I put a top coat of black paint over that.
