-   -   Install issue of M&K muffler (http://forums.pelicanparts.com/porsche-911-technical-forum/450575-install-issue-m-k-muffler.html)
pkpenny 01-09-2009 11:21 PM
Received my M&K 1 in 1 out muffler today which I purchased from our host. I bolted it to my Fab Speed Cat bypass with no problem. I am having no luck getting the circle clamps that came with the muffler installed. One of the clamps is slightly bigger than the other. They seem to be short as I cannot get them to connect. Any advice is appreciated. 1987 911 Targa.
Wayne 962 01-09-2009 11:24 PM
Can you post some pics?
-Wayne
ikarcuaso 01-10-2009 12:24 AM
You can't clamp either one, even the larger one? Ben told me the small one for an SC, big one's for a Carerra), and that it's OK to use just one. I used both anyway.
Yes, pics would help. You can also call Ben. He's very helpful.
mb911 01-10-2009 03:44 AM
can you read me the numbers off of the clamps? I susppect someone put the wrong clamps in the kit, I will send you the correct ones right away if thats an issue
pkpenny 01-10-2009 07:47 AM
250 127/ 861 and 250 135./860.
deshetlr 01-10-2009 08:04 AM
If Ben finds the clamps are correct I suggest 3 things. First do not snug down the bolts to the bypass until everything is loosely installed. Second, the T mounting bracket is adjustable so loosen it as well and try again. Finally I had an aftermarket system on before the M&K and whoever installed it bent the T bracket so I also had to remove the bracket, straighten it out and re-install. Once everything is installed then snug down the bypass bolts and then the clamp.
john walker's workshop 01-10-2009 08:08 AM
longer bolts?
pkpenny 01-10-2009 09:05 AM
I was able to used the larger clamp closest to the exaust outlet and looks as if its going to work.
Bearded Viking 01-10-2009 09:09 AM
Yep, that's what I did too. One clamp. It's been on for a few months now. No problems.
You're gonna dig the sound!
mb911 01-10-2009 09:41 AM
Yes the 135 is all that is needed in some applications the 127 is required but typically not. I like the 135 without the spring that way you have a bit more room
plug&play 01-10-2009 02:07 PM
I just installed just installed an M&K on an 87. It also came with a 127 and a 135 clamp. I put the 127 on the passenger side of the muffler. It was a tight fit. The 135 was too big to clamp down. I looped it across the flange on heater pipe crossover that lined up with the muffler bracket. Don't know if this is correct, but it seemed to work.
http://forums.pelicanparts.com/uploa...1231628860.jpg
mb911 01-11-2009 02:32 PM
yup thats correct it just needs to stop any rattle between the 2 pieces
dimeified 01-11-2009 02:36 PM
On my car, the furthest one in the picture is the larger one, and wraps around the muffler AND the heater crossover pipe. The one closest should be the shorter one, and wraps around the muffler and the muffler to chassis bracket.
