-   -   Will a Cis system from '82 work on a '79 motor? (http://forums.pelicanparts.com/porsche-911-technical-forum/450706-will-cis-system-82-work-79-motor.html)
jax911 01-11-2009 01:18 AM
I guess the real question is, can I use the '79 wiring harness? or, what else is required for install?
Thanks, Jack.
jax911 01-11-2009 04:48 AM
More clarifacation:
I have a '79 3.0 with carbs, I don't like the carbs and want to install CIS. I have access to a free '82 cis system and need to know if I can use the '79 engine wiring harness or is it different in '82.
Also, is the computer box under the seat the same or different?
Vin-barrett 01-11-2009 04:55 AM
Unless the 82 system is from a ROW car, the intake runners will be too small. Also the Lambda brain and wire harness is different because the 82 uses a frequency valve.
I would get the correct 78-79 system.
Aurel 01-11-2009 04:56 AM
What computer box? Those are only on Motronic (after 84).
jax911 01-11-2009 04:59 AM
Thanks Vinny,
I knew there was something different, hadn't thought about the intake runners though.
ChrisBennet 01-11-2009 05:52 AM
The later SC's still has CIS but it incorporated an oxygen sensor and a little computer that controlled a frequency valve to alter the control pressure and thus the mixture.
-Chris
pcar9119 01-11-2009 06:19 AM
I don't think your going to like the swap. You won't get the throttle response out of the cis that you do out of those carbs, if the carbs work properly that is. If you going back to FI i would go for the motronic unit, not the CIS.
jax911 01-11-2009 06:37 AM
Can I put a motronic FI from a 3.2 on it? That would be ideal.
Aurel 01-11-2009 07:18 AM
In short, no. But you could use Motronic intake runners from a 3.2 with a Tbitz EFI conversion
http://forums.pelicanparts.com/porsche-911-technical-forum/372213-motronic-3-2-3-0-sc.html?highlight=cis+motronic
http://www.bitzracing.com/gallery/Mike_79_911SC.html
