(the shotguns)
How does front sway bar drop link fit on early car?
My sway bar drop links have a bend at one end; can't recall if this goes on the a arm or the sway bar clamp (through the body style). And which way does the bend point; out or in?
i've looked at Haynes, Waynes and searched. Help!
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
(the shotguns)
Thanks fleiger but my bar is a bit different
