Guest
Posts: n/a
Heeeey,
I have one of those pressure regulators too! Until my mechanic told me what it was I referred to it only as "shiny round thing with dial on it"! So, tell me what pump to get. I looked at pp online catalog and the only thing they had was $235?? I always try to patronize but I don't want to spend that if I don't have to! Other cataologs have rebuilt for approx 140-165. The pump pictured above looks cool (shiny, like pressure regulator!). I could easily fabricate a bracket out of something to hold it in there, otherwise do I just hook it up and I am all set? |
Guest
Posts: n/a
Carter, as well as others makes a small, inline pump available at auto parts stores for cheap. make sure it only puts out 3-5lb pressure or you will need a pressure regulator between the pump and the carbs. the cheap chrome regulators with the twist dial are prone to failure.
Guest
Posts: n/a
Al of this talk about pumps and lines for carbs has me wondering a few things. It looks as if the previous owner for my car - 1970T w/Webers - has put in a aftermarket pump ~3-4 pounds pressure, and re-routed the fuel lines. Most diagrams show two fuel lines: one to the pump and regulator and a second return line to the fuel tank. My car only has the line from the pump to the carbs. connected - No return line. Is there a problem with this configuration?
Guest
Posts: n/a
All of this talk about pumps and lines for carbs has me wondering a few things. It looks as if the previous owner for my car - 1970T w/Webers - has put in a aftermarket pump ~3-4 pounds pressure, and re-routed the fuel lines. Most diagrams show two fuel lines: one to the pump and regulator and a second return line to the fuel tank. My car only has the line from the pump to the carbs. connected - No return line. Is there a problem with this configuration?
