LOK LOK is offline
Camshafts questions
Hello everyone
I have 2 questions that I hope can help me
Can I use 3.2 camshafts in my 3.0 sc and if you can, it will give a little extra?
Fits a 964 cam shaft at a 3.0 sc engine
Power distribution from a 964 with dual ignition can be mounted on a 3.0 sc
Or have other proposals for dual ignition?
Thank you in advance for your help
Sincerely, Lars Knudsen
Old 01-13-2009, 04:41 AM
Bill Verburg's Avatar
Originally Posted by LOK View Post
Hello everyone
All n/a 3.0 and 3.2 use cams w/ the same timing(234°/226° I/O duration, ovrlap 1mm) and lift, over the years they have been advanced or retarded set over a 6* range.
from '81 they all even have the same part #s,
yes, you can use them but no there is no improvement
There are several here using the 964 cams(240°/230° I/O duration, overlap 1.26mm), with a little more lift. The concern is piston clearance. I don't know what p/c sets they run
you can run the 964 dual ignition but the 3.0s all run backward from all the others, so the distributor drive gear on the crank needs to be changed
Bill Verburg
Old 01-13-2009, 05:56 AM
LOK LOK is offline
Thank you for your help
Old 01-13-2009, 11:21 AM
