darthracing's Avatar
Send a message via Yahoo to darthracing
Y.A.I.M.C.D (yet another iPhone mount clock delete)
Okay, inspired by the Ultimate iPhone mount here on the board, I collected parts for a 30 minute construction to installation project with photos.
http://www.darthracing.com/911_ya_iphone_mount_clock_delete
And only photos - the Google site I have access to has terrible editing facilities - it took much longer publishing whats there than doing the project.
Materials:
1. 3" fiberglass-like drain grate from Home Depot
2. Cheap universal phone/PDA mounts off eBay
3. Zip ties - mount to drain grate
4. Bicycle tube piece - a "gasket" to stabilize/fill in the space not covered by the grate
5. Rubber bands to hold tube in place
6. sissors to cut excess zip tie
Assembly:
1. thread zip ties through mounting holes of PDA vise
2. hold chunk of bicycle tube on grate using rubberband
Installation:
1. remove clock - tape the contacts, don't loose the little bulb within. (Possible use for charging phase 2, or even lighting). Put clock in safe place in case we want to use it again.
2. adjust gasket towards the grate facing
3. try the iPhone in the vise grips, adjust to taste
Test:
1. try Google maps app
2. try iPod to Stereo AUX - not much room for the plug, device top faces forward
Next steps:
0. test in moving vehicle
1. try running AUX wire from kickboard to upper dash behind/through the mount - non-trivial going from lower to upper dash during initial attempt
2. run a charger off the clock power behind the mount
3. try old-school iPod
86 Carrera Coupe (sold)
11 Nissan Leaf
03 Honda Civic Hybrid
91 ELECTRIC Kawasaki ZX-11
Old 09-21-2009, 11:48 PM
Tags
iphone mount clock delete
