Anachronistic Anomaly
Ultimate 911 iPhone Mount / Homemade Clock Delete
Seeing as how there's all these great driving/performance Apps for the 3G iPhone, the question arose, "What would be the best way to mount said phone in a solid position that will still get satellite reception and won't block my field of view?"
1. I don't like the big suction cup thing mounted to the windshield. First off, it's fugly. Second, major visual block. 2. I'm not going to mount anything to the top of the dash or in the small crevices of the dash face. 3. Vent mount? Possibly, but the vents on these old cars tend to get a little brittle. Mine are perfect and working, so I don't want to risk it. SOLUTION: Make my own Clock Delete and mount the iPhone to that somehow. Instead of paying $50 for a replica Clock Delete (look on ebay), I figured I could probably make one on my own. Nothing perfect, mind you, but very close. So I started by going to best buy and finding these. This kit is a vent mount as I mentioned earlier, but also a versatile "stick-on" job. I'll just be using the stick-on parts from this $10 kit. ![]() Next up, a case for the iPhone so I don't have to stick anything directly to the phone itself. I chose this case because of the hard plastic shell. Most of the cases are these rubbery sleeves that I don't think would stick very well and would be more prone to jiggling around once locked into place. It was around $20. ![]() Next part is to make a mountable case with one of the pieces from the mounting kit. ![]() ![]() ![]() The added bonus of having the stick-on piece on the case is that I can take the case off of the iPhone when I carry it around in my pocket. I won't have the bulky stick-on jabbing my hand whenever I reach for it. Now to the Clock Delete. I went to Home Depot and bought a vinyl drain grate with a 3" lip and a slightly smaller recess that was almost the exact same size as the VDO clock. It cost me all of $2.00. Then I used an old DVD case to cut out a face for the grate (made sure to cut it out a little big to allow for sanding afterward). Glued it on the grate with some 3M spray adhesive. ![]() Sanded down the edges with a Dremel and done! This is the finished version after spacing out proper placement of the stick-on mount. ![]() The question now is, "Does the factory gasket fit?" Sort of. To use the factory gasket I would have needed to evenly sand down grate to fit. Screw that. I'll keep the gasket on the clock to preserve the gasket and make for an easy swap when needed. Instead, just wrap the grate in gaffers tape until it's nice and snug in the dash. ![]() ![]()
IG@ the_derek_whitacre Last edited by lfot; 01-16-2009 at 02:13 PM.. |
...continued.
Pop it in the dash, and you've got a very solid, handily placed, hands free phone / GPS unit / lap counter (Track Day app), Dyno and g-force meter (Dynolicious App) / whatever else you can think of. ![]() ![]() ![]() ![]() Google Maps GPS ![]() Dynolicious app ![]() Track Day app
IG@ the_derek_whitacre |
Author of "101 Projects"
Neat idea!
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
you see Arthur...
Nice work. The best kind of upgrade, cheap and effective
J 82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat 06 Cayenne S 00 ML 55 AMG Santa Cruz Bullit |
It's a cool idea Derek. It's hard to tell from the pix, but can you see it OK when you are in the drivers seat? If so, I wonder if the same would apply with my steering wheel (stock).
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Go Speedracer, go!
Nice! I did something very similar in my Audi with my Blackberry. I used a magnet and had similar results.
1981 SC ROW Coupe |
'82 SC TL
Neat, nice work!! If you ever miss the clock....just download a working pic. of actual clock & you're almost OE.
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
I can see it fine. Can't comment on your stock wheel though.
Sweet!
Jim 911 Mint Green "RSC" #mintgrun 911 Gentlemen's Rallye 85 Carrera GP White 2012 C63 AMG Mars Red |
driver
nice job derek!
- chris Street: 1971 911E, 2007 GTI 2.0T, 2012 Cayenne Turbo, 2019 GTI TCR, 2022 Boxster 25 years Circuit: 2020 Cayman GT4 |
Nice. I might try this, WITH the addition of running the ipod stereo connector through the "delete" so I can plug music/audio from the iPhone.
86 Carrera Coupe (sold) 11 Nissan Leaf 03 Honda Civic Hybrid 91 ELECTRIC Kawasaki ZX-11 |
Is your oil temp/ pressure guage and speedo rotated?
I think I may have seen that on ther pictures maybe your car or someone elses. Any reason for it?
1978 911sc Targa Sold 2001 996 Cab Sold 2006 Cayenne S Silver Wifes Car for sale 2011 Jeep Wrangler Silver for sale 2010 Toyota Prius Black for sale 2016 BMW 328D wagon |
Guest
Posts: n/a
Nice!
Shane - 1984 928S |
i thought it was to create the illusion that the oil pressure remains constant.
Almost Banned Once
But also as stated earlier it helps see the important numbers... For instance, you can rotate your taco so when the needle is at "red line" it's pointing straight up >>> Easier and faster to see at a glance during the stress of racing. Just one of the many things I like about our cars....
- Peter |
Seeing through the smaller than stock steering wheel will be my excuse - I use my tach already to estimate
speed because I can't see 60-90mph, I'll be trying a little rotation myself. -T
Doesn't dynolicious have to be on a flat surface to work?
Ferdinand Magazine
Sweet little mod - top work!
Sheriff at www.impactbumpers.com Brand support at classicretrofit.com/tuthillporsche.com 1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles |
It's the smaller than stock steering wheel. With the gauges tilted the way they are, I can see everything at a glance without moving my head over to see the temp, or pressure, or mph.
