Southern Class & Sass
H4 Headlights installed!
Perhaps you'll recall, I had one of the original H5 headlights on my '88 break. I used that as a reason to upgrade to a set of really nice used H4s. A bit of an extravagant project since I rarely drive the car at night,
I finally got around to installing them today. I hooked up the city lights, and installed the relay kit from Pelican. Now all I need to do is get the H4 trim rings painted, and install some 3M protective film over the lenses. Here they are installed ![]() City lights on ![]() Low beam ![]() High beam
Dixie Bradenton, FL 2013 Camaro ZL1 Last edited by Dixie; 01-16-2009 at 02:40 PM.. |
Member 911 Anonymous
Congrats and Great Job!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
What connectors did you use to the lamps and where did you get them?
1984-911 M491
Just curious, how long did it take you to screw in the trim ring lower attachment fastener?
1984-911 TLC......SOLD |
Where did you get the "city lights" did they come with the H-4's? I have the provision for them but no light or mount?
Scott
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
When I did mine last year, I spent 2 hours the first day, 1.5 hours the next day, and at last on the third day after about 1 hour attempt, I managed to get the driver side ring in place. The passenger side ring somehow got in at very first attempt. frustrating... Now that was on an old seal. Just thinking about replacing the seal with new makes me twitch...
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
Dixie Bradenton, FL 2013 Camaro ZL1 |
Searching the Pelican Forum showed an easy way to get power to the lights. You simply make a "Y" connector using 16 ga. wire, and some male and female spades. You unplug the connector for the grey/black wire. This wire runs to the corner lights. (Yes, the corner light wiring runs through the headlight bucket.) Reconnect the grey/black wires using the "Y" connector. The extra lead on the "Y" goes to the city light. You'll also need to make another "Y" connector so you can run a ground to the city light. At first, I erroneously assumed the city light would ground through the headlight assembly. But without the ground wire, they wouldn't light.
1984-911 M491
Thanks!
Regards, Scott P.S. It was probably you who posted the original thread.
