My 911 has "parkinson"
hi its a 76 2.7
i think it happened after i had a "hidrostatic lock" , i fixed the lock , change the oil as it was full of gasoline and now just in about 2000 rpm the car shaking in every gear. if i accelerate or deccelerate (staying on the same gear) it stops!
i also changed one of the coil cables
is it something i should check with the gasoline or electrical?
911 TARGA 1976 - 3.2L, G50 SHORT BELL HOUSING.
Toyota Hilux 4x4 2000
VW tuareg 2009 3.6
HONDA SH350
Old 01-18-2009, 01:32 PM
pozee's Avatar
Is it definitely drive train related (not suspension/tires etc..?)
If so, is it clear that the engine is mis-firing?
Some clarification will help.
pozee
Old 01-18-2009, 01:42 PM
Check and make sure your clutch cable tube between the fire wall and the transmission case is well clear of any items such as the accelerator crank shaft.
Old 01-18-2009, 02:35 PM
Administrator
Jack Olsen's Avatar
Um, how long was it running with gasoline thinning out the oil? Yikes.
Old 01-18-2009, 03:00 PM
Originally Posted by jack olsen View Post
um, how long was it running with gasoline thinning out the oil? Yikes.
just a few minutes and i tow it to the garage...
Its not missfiring ...
Anything i can check before im going to the mechanic...
VW tuareg 2009 3.6
HONDA SH350
Old 01-18-2009, 03:26 PM
Originally Posted by wayne at pelican parts View Post
sounds like it's not running on all six cylinders. Get your infrared thermometer and check the temps of the exhaust pipes and see if any are much cooler than the others.
-wayne
wayne when i eccelerate the "parkinson" stops n the engine goes very strong (as 2.7 can be...) do u still think it might be a cylinder?!
VW tuareg 2009 3.6
HONDA SH350
Old 01-18-2009, 03:29 PM
ruf-porsche's Avatar
Was this car own by Michael J. Fox?
dn ǝpıs ʎuıɥs ǝɥʇ dǝǝʞ
Old 01-18-2009, 03:44 PM
poor guy...
anyone?
VW tuareg 2009 3.6
HONDA SH350
Old 01-18-2009, 04:13 PM
Does it do this at 2000 rpm when in neutral? What caused the lock and what was the fix?
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 01-18-2009, 04:46 PM
nothing in neutral
i dont know the cause probably because i tried to start it while one of the coil cables burn out and too much gasoline without the electronic strike (sorry for my poor english)
the fix is to open the plugs and change them to new ones + change of all the oil as gasoline got inside the oil tank
VW tuareg 2009 3.6
HONDA SH350
Old 01-18-2009, 08:24 PM
No vibration in neutral means the source isn't in the engine. It's either in the drivetrain (e.g. clutch, transmission) or something attached to whatever is rotating in the drivetrain (e.g. half shaft, tire/wheel). It could also be a worn or loose motor or transmission mount.
My best guess,
Sherwood
Old 01-19-2009, 01:41 AM
Yeah, if you are going down the road shaking and you put it in neutral and the shaking continues, it must be something other than the engine. If its coming from the engine under load, I would check the other ignition wires. They can cause misfires that only show up under load.
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 01-19-2009, 08:19 AM
