KoenigsTiger's Avatar
Question What is this little Black box? 911SC
Hello Everyone,
I was wondering for quite sometime what this little black box it for? It's in the trunk compartment, under the dash board of a '82 911SC. The car had sunroof, cruse control, power mirrors. Is it part of one one of those systems???
Thanks!
Gene
P.S. Photo used from someone else's post, thanks for that!
Old 11-19-2011, 02:14 AM
mca mca is offline
mca's Avatar
I'm guessing rev limiter. I used to know the answer but my memory is failing me right now.
Old 11-19-2011, 02:54 AM
Exotic Vehicles are here
1-ev.com's Avatar
KoenigsTiger,
The "best" way to know is to unplug it and see that will stop working .... :-) LOL
but, if seriously, You might need a wiring diagram ....
My 2c.
-Y
"Y" <- My favorite question...
+ '68 911
+ Helping your business to get more business: http://myWWWapp.com
Old 11-19-2011, 05:27 AM
Thumbs up
Yeah, I should have done that... since I do have a Bentley manual....
Thanks for the reminder
Old 11-19-2011, 05:47 AM
Almost Banned Once
sc_rufctr's Avatar
That doesn't look like anything I've seen in an SC. It may be a dealer installed alarm.
- Peter
Old 11-19-2011, 06:02 AM
Gene,
It is the switch that turns off the fuel pump circuit when the engine speed exceeds 6700 rpm.
Paul
Old 11-19-2011, 06:32 AM
Thumbs up
Thank you Paul!
I looked in the Bentley, but there was no actual picture of the box.
So I guess this is a kind of a RPM limiter. Does the CDI box some sort of a limiter also? Or is this the only one on the 911SCs?
Paul thank you for the other posts regarding CIS, those have helped me out this summer...
Thanks guys!
Old 11-19-2011, 06:41 AM
RETIRED
Joe Bob's Avatar
Euros have a limitter in the rotor....
2012 ML350 3.0 Turbo Diesel
Old 11-19-2011, 06:48 AM
Gene,
No ignition limiter. The reason is that if you continue to dump fuel through the CIS sprinkler system at 6700 rpm with no fire, the converter life goes out the window.
Paul
Old 11-19-2011, 06:54 AM
Hmmm, good to know!!! Thank you for the info gents!
Old 11-19-2011, 07:02 AM
they can have a wierd failure mode, where they momentarily shut off the pump. repeatedly. they can be unplugged with no performance issues, other than no over-rev protection.
206 637 4071
Old 11-19-2011, 08:11 AM
Peter Zimmermann's Avatar
You are so right! The first time that my shop was presented with the intermittent problem it was not exactly an easy, quick, fix!
Keep the Shiny Side UP!
Pete Z.
Old 11-19-2011, 11:02 AM
