Nine11cab
83SC Transmission shifting problem when hot
I have a 1983SC, the transmission shifts great when the car is cold but when it gets hot the shifter will grind and not want to go in gear. Any suggestions would be greatly appreciated.
Old 12-20-2014, 05:59 AM
Oh Haha's Avatar
Not so much heat related but...
Check the clutch cable for proper operation. Adjust as needed.
Check the shifter related bushings as well as the coupler.
It could be an internal issue but start with the easy things first.
There are several threads on these tasks which will give more detailed info.EDIT> How many miles on the gearbox? When was the fluid changed out last?
Pacific Blue
Wayne
Old 12-20-2014, 06:19 AM
Fleabit peanut monkey
Bob Kontak's Avatar
+1 on what Oh Haha says. Nail the basics. Take your time. Search using the advanced search function. There is so much info here your head will spin.
Tell us a little more. Did this just occur?
1981 911SC Targa
Old 12-20-2014, 08:35 AM
Rescuer of old cars
Arne2's Avatar
What about gear oil? Too slippery/thin when it warms up? A 915 requires some friction for the synchros to work.
With Kendall dino-oil in my 915, it has some resistance when cold, but shifts fine warm.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 12-20-2014, 09:25 AM
schoward's Avatar
Feel like ensuring proper fluid type is a good place to start. Too slippery or certain synths not good for the 915. I've used swepco 201 and Kendall nsmp - prefer the swepco 201.
Scott
1981 911SC Targa - Platinum Metallic
Old 12-20-2014, 09:33 AM
BER BER is offline
BER's Avatar
Porsche Crest
As "Arne2" and "schoward" have said, make sure you are not running synthetic gear oil in a 915 gear box. The 915 likes dino oil.
I use Swepco 201 in my 915 gear boxes, but Kendell dino is also an excellent gear oil.
BER
Old 12-20-2014, 12:10 PM
Nine11cab
Thank you all very much Great Forum
Once again can't stress how much I appreciate all the feedback. I will start with the basics as indicated.
Old 12-20-2014, 02:08 PM
