Recreational User
porschenut's Avatar
RS front oil cooler - how to route the oil lines?
I've just embarked on my next project - turning my 86 Carrera into an RS clone (I know...don't say it ). I want to replace the fender-mounted Carrera oil cooler with a front mounted one, but I'm not sure what's the best way to route the oil lines back to the thermostat in the rear. I'd like to route them away from the front jack point where they go under the car, to reduce the chance of them getting crushed.
I also don't care much for them being visible from the right side of the car like the current hard oil lines are. I don't plan on using stainless steel braided ones unless I really need to.
For you guys who have this arrangement, how did you do it? Would they be safe mounted further inboard so they're more hidden?
Old 01-21-2009, 09:15 PM
Bill Verburg's Avatar
The stock location is the most protected for the longitudinals unless you want to run them through the cabin
Once you get to the fender well there are 2 choices
1)use braided line to go around the inner edge of the tub
2)run braided hose through the tub
here's an example of #2, a factory RSR
and an example of #1
Bill Verburg
Old 01-22-2009, 05:00 AM
Tom '74 911's Avatar
Here's a few more. The silver and orange cars are not mine, but are from my photo stash. The notated fender cooler is mine and shows how I plumbed my front cooler and fender cooler in line together. I went w/an Elephant Racing kit.
Hope that helps,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 01-22-2009, 09:34 AM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Originally Posted by Tom '74 911 View Post
Hey, that's my cooler! I guess I don't have to mention what I'd do.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 01-22-2009, 10:06 AM
Sorry for taking credit for that one Ryan! I though it was my car! I had that photo in my stash and must have used it to help me plumb my lines - Thanks!
Tom
Old 01-22-2009, 10:20 AM
boba's Avatar
Here are some routed from the hard lines to the cooler.
Old 01-22-2009, 03:42 PM
Recreational User
porschenut's Avatar
These are some interesting suggestions...thanks. I'll probably have to keep the routing the same from the rear of the front fender to the back. Now I just need to decide if I want to replace the entire length of the hard lines with new hose.
Old 01-22-2009, 06:33 PM
Keep the hard lines if you want the oil flow profile to remain low. Flex lines will make this even more apparent.
MHO,
Sherwood
Old 01-22-2009, 08:49 PM
