Side Mirror Swivels 85 Targa 911
What keeps the side mirror's from folding in when driving.
My mirror was hit and now it's very lose. I can pull it off and on at the base knob. Is this even fixable. It looks like there are a set of teeth in the upper housing. They might have been stripped when the mirror was hit. Any ideas?? |
Can aslo be the spring- there is a rod/bolt between base and head of the mirror with a spring around it. petrhaps the spring broke.
You may need to completely remove the mirror, undo the wiring etc and thread the screw portion of the tube into the nut. I removed the plastic bushing I believe when I didn't have quite enough thread to grip it any longer
911SC Tinkerer
Heres the diagram from the Porsche Pet (1986), Yours will be similar:
![]() - Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
On my 85 the aluminum threads on the mirror base stripped out. To many years of folding them in and out I guess. Anyway that spring (#18 in the diagram above) is strong enough to use as coil overs for a truck. Well, maybe I exaggerate a tiny bit. It is STOUT however.
If you have VERY strong hands and arms it will compress a bit and you can tighten it up. ![]() This is the base of the bolt you will have to turn. ![]() ![]() This a holder I made from a flat piece of steel. That way I could put it in my vice. ![]() I took these photos to show how I put it back together. I had to buy a new mirror from a junk yard. All I needed was the part mounted to the flat metal part. It is the part that screws onto the back of the flag (6a in drawing) I had to have a body shop paint it to match. I used a Torx bit but so I could push straight down. ![]() Good luck. It is a strength test. If you know a local gorilla that hires out or someone with strong hands invite them over and have them help.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Excellent explanation. Thanks gentlemen.
