LinkBack | Thread Tools | Rate Thread |
Follow me
Hey All, So this morning I went to move the car into the garage. It was about 10 degrees and going to snow. As I started it BOOM! Now It wont start at all. I'm sure I blew up the air-box but I'm not certain. My questions are... what should I do? And what parts am I going to need to fix it also Is this a job I can do myself. Thanks for your help. Jake
1982 911SC |
Seymore,
Yes you can do it yourself if you have some mechanical skills. I did this recently without dropping the motor, tricky yes but do-able, worst part was getting the screws back in which hold the cold start valve to the back of the air box. See this post for some details, I have a list of parts needed as well somewhere will find and post for you. Dived right in
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
Wildman Emeritus
Seymore,
I feel your pain as I blew mine after doing a drop & trans rebuild. Davy is correct, it can be done without an engine drop, but I was so frustrated that I had it flatbedded away & paid to have it done. Just be ready for some serious contortions. Oh, I did have a pop off valve when it blew. Also had one installed in the new airbox as an extra precaution.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Bollweevil
Check to be sure the rubber boot from the air flow sensor to the throttle body hasn't just blown off on one end. Before I installed the pop-up valve, on several occasions when backfiring my '74 CIS blew the boot off of the throttle body..
Maybe you are lucky and this is the problem ??
Jack 74 911 Coupe 2.7L - K21 Option - S suspension |
if you have to replace the box do a partial engine drop. it's well worth it.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Take the engine out and do it right.
Keep the Shiny Side UP! Pete Z. |
Follow me
How hard is it to drop an engine? I dont know if im up for that. I can do a little engine work but that sounds tricky. Do you just undo the motor mounts with jack stands under the motor and jack up the car?
1982 911SC |
Somewhere in the Midwest
I've removed and installed CIS without a drop, and it is not bad. A partial drop will provide more access. You only have to drop a few inches to make a big difference.
I would recommend taking the entire CIS out and then replace the box on a bench. Removing the entire "spider" is not difficult, but if you try to replace just the box while the system in on the engine....good luck to you. Removing the CIS - start with the top boot and all connections. If you have AC and Heat, you'll want to remove those. Bag and tag everything if you are not familiar with the CIS. Study all the pictures and diagrams you can find so you have a mental picture of what you can't easily see while removing the system. The only special tool you'll need is a 13mm socket with the universal joint on it. I purchased a 1/4 and 3/8 inch drive version from Sears to use with extensions I had in my tool box. |
Use the search button for both engine partial drop, and engine removal, I'm sure that you will find plenty of info.
Here is a good thread on Rennlist replacing the airbox with a partial drop.
http://forums.rennlist.com/rennforums/showthread.php?t=432772&referrerid=27687
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Excellent reference! There will be some differences on the '82 (breather hoses, frequency valve and harness are a couple), but iceman's approach and organization are terrific. By the way, his car turned out great and runs well.
Removed mine last weekends in 45 mins, no drop. Remove the air boot and the cruise bracket and you have just about the same amount of room as a partial drop for a fraction of the time,
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
i think installing it with motor in the car would be difficult. out is easier.
poof! gone |
It's really not difficult at all guess. I can think of a few other tasks more frustrating than install CIS on the engine w/o a drop. |
Follow me
Well it seems about 50/50 on droping the motor or not. So I think I might get what info I can and just see for myself how hard it is. If worst comes to worst Ill drag it into the shop and pay someone else to do it. Thanks for all the info everyone. Oh 1 more question does anyone have a parts list of what im going to need. Thanks again.
1982 911SC |
souk may be right...but coming out, you dont have to be all neat...
i have taken a system OUT in a car once..we were going to carbs, so IN was never explored.
poof! gone |
Uh oh maybe I should install a pop off valve on my 82 SC. Probably right after I install the hydraulic chain tensioner, and right after I change over the Dilivar studs.
Or maybe I'll just sell it as the only unmolested SC Targa left in the world. Last edited by ruf-porsche; 01-24-2009 at 09:37 AM.. |
Seemore in DC, you have a pvt msg.
Old Tee all 911s sold |
