Mo money = mo parts
Rocker Arm Removal
Wayne's rebuild book says to remove rocker arms through the narrow flange on the cam tower. I really don't want to pull the timing chain cover and housings off and have to retime the cams. Is there a problem with pulling the one or two shafts out through the thicker flanges? This is an old photo. My heads towers are still on the motor. Thanks.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 03-03-2012, 08:48 AM
Mo money = mo parts
I am referring to #1 and #4 when I say one or two shafts. For example #1 exhaust can't come out through narrow flange with chain housing installed.
Greg
Old 03-03-2012, 08:51 AM
Chain fence eating turbo
It does not matter which side you pull the shaft through, they're dimensionally identical as the shafts are too.
Old 03-03-2012, 08:59 AM
Mo money = mo parts
Great, thanks Tippy.
Greg
Old 03-03-2012, 09:18 AM
the issue is the dirt and corrosion that collects in the thick side. clean it out first before removing the shaft.
206 637 4071
Old 03-03-2012, 11:31 AM
Mo money = mo parts
John - My #4 intake won't budge. Any suggestions? Heat?
Greg
Old 03-03-2012, 01:34 PM
Mo money = mo parts
I got it. I hit it just hard enough with a hammer in the opposite direction it needed to come out to free it up, then was able to get it out the other direction.
Greg
Old 03-03-2012, 01:51 PM
