is there a difference between T and S distributor ?
Hi
I plan to upgrade my 2,4T engine to S spec. (Weber 40 IDA, 9.5 CR JE pistons, S cams, S heads, MSD ignition, SSI exhaust) If I put a pertronix and an S rotor in my stock distributor, will it be OK ? will it need to be recureve or recalibrated ? ThanksSmileWavy JD |
Here are the advance curves for the 2.4 and 2.7 engines, pre cishttp://forums.pelicanparts.com/uploa...1233200117.jpg
They all use essentially the same spec 5*ATDC@900 w/ vac. connected and <38*BTDC @6kw/ vacuum disconnected |
| All times are GMT -8. The time now is 04:05 AM. |
