-   -   smoke when accelerating during a right turn lean (http://forums.pelicanparts.com/porsche-911-technical-forum/454073-smoke-when-accelerating-during-right-turn-lean.html)
WIL84911 01-28-2009 06:48 PM
do this sound like an oil pump going?
myfast911 01-28-2009 07:05 PM
valve guides
WIL84911 01-28-2009 07:34 PM
Thanks! does that mean 'rebuild'?
john walker's workshop 01-28-2009 07:40 PM
try keeping the oil level one quart low.
stealthn 01-28-2009 07:42 PM
A few questions;
- Is it only under acceleration, or does it do it under decel?
- Does it only do it during a right hand turn or both directions, what kind of turn, hard long sweeper, etc.
- What year and engine 911?
- What colors the smoke?
WIL84911 01-28-2009 08:03 PM
happens only during acceleration on long hard right hand sweeper. engine is an 84. smoke appears to be white. intake/exhaust ports looked good from a recent plug change/SSI installation.
WIL84911 01-28-2009 08:05 PM
oh and oil level is just above the dipstick mid range. are you saying drop it some more?
carrera turbo 01-28-2009 08:47 PM
dumb question but is the tire rubbing?
ed
john walker's workshop 01-28-2009 10:00 PM
mid range oil level as well as a restrictor in the hose between filler neck and intake. the restrictor is stock, but sometimes they're missing.
WIL84911 01-29-2009 07:23 AM
carrera turbo, tire rubbing probably not an issue as there's more than enough clearance and I can actually see the smoke coming from the tailpipe area. thanks.
John, will research into the restrictor issue. Thanks.
c019740 01-29-2009 08:55 AM
I had the same problem. It was too much oil - need to start by dropping a quart or so...The oil is getting in the air box. Check the box to see if any oil is in there too! odds are there is.
WIL84911 01-29-2009 09:26 AM
thanks c01! based on feedback I believe too much oil might be the root cause. where is that airbox by the way?
john walker's workshop 01-29-2009 09:45 AM
3.2s don't have one.
WIL84911 02-25-2009 01:07 PM
OK I've dropped oil to almost at the lowest point of the dipstick. Smoke is less but still there during hard acceleration. Can I drop some more? Any ideas why this is happening after an SSI install? Could it be because I stayed with the stock oil lines? I had the SSI installed away from home and when we found out we were missing oil line parts we decided to force fit the existing oil lines.
WIL84911 05-22-2009 07:45 PM
I think this may be a big part of the problem. Started puffing blue smoke and I had to stop. Needed piston rings & crankshaft bearings. In other words $10K worth of fixes (Grrrr!!!!).
Still waiting to get it back. I've been in withdrawal mode for the past 30 days.
