AutoBahned
plating pedal cluster parts
Any reason not to plate the pedal stalks and "cup" in the pedal cluster?
Mine were painted black, but it seems like plating would last longer and be less likely to rust again... Thoughts? |
Navin Johnson
I had my pedal cluster rebuilt and plated by a fellow on the 914world board.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 01-29-2009 at 06:38 PM.. |
Navin Johnson
forgot the pic
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Tim:
I have an older pedal cluster stored away somewhere; other than the 2 piece clutch pedal, is there any difference between the later one piece? Can you use it in a later car (3.2)? jp |
tim
that redefines "BLING"! "gold plated porsche" comes to mind( sorry sw)
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
I'm going to be rebuilding my pedal cluster in the next couple of months. I plan to yellow zinc plate it and then clear powder coat over that for added protection.
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
The purpose of plating should be for structural metal corrosion protection and not ‘bling’. If plated, I would want to see the parts over-painted as original.
‘nuff said. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Hydrogen embrittlement of plated parts comes to mind. Not sure of the forces generated onto the brake pedal, but I'd look into the consequences of this process. Original structure strength can be retained by correct heat treatment.
Sherwood |
Less brakes, more gas!
I would not worry about the embrittlement in this case. Loads are not big even if you are standing on the brakes. Springs might fail, but unlikely IMHO. Susp. gear is another story entirely.
-Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
GAFB
Pedal cluster is an ideal application for POR15.
Several BMWs |
AutoBahned
Tim - what type of plating is that?
Navin Johnson
Don't remember what type of plating that is..
Contact for the guy who did it http://www.pmbperformance.com
powdercoat
i powdercoated mine.
i think its bulletproof and looks original
