rbuswell's Avatar
Porsche Crest Where do you find these? (pic)
This is an engine that recently sold on the Pelican Used Parts forum. I really like the plug wire holders pictured that reach over the fan housing and bolt down with the bolts that hold down the shroud. Are these common to buy and I've just never seen them or are they difficult to source. Thanks everyone for your help.
1982 911SC
1987 924S
Old 01-24-2009, 07:11 PM
muck-raker
kidrock's Avatar
I'm pretty sure those are the Beru plug wires. OEM equipment. Pelican has 'em.
Old 01-24-2009, 07:30 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
The holders themselves are stock as well if that is what you are asking about....Pelican should have them as well.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 01-24-2009, 07:38 PM
rbuswell's Avatar
Porsche Crest They look a lot different in the PET
The parts shown in the PET that do the same job as these are quite a bit different. They appear to have two metal screws through them and fasten to the fan housing using a bracket.
1982 911SC
1987 924S
Old 01-24-2009, 09:12 PM
EMT/TechRescue Instructor
86911cab's Avatar
I have them on my engine. The part number on holder is 991.602.185.00 (Beru). They are 2 bolt holes on the fan housing that they bolt to.
Old 01-24-2009, 11:14 PM
3.2Carrera's Avatar
i like the carbon fiber, I want one!!!
-Joey B.-
1985 Carrera
http://www.pelicanparts.com/gallery/3.2carrera
Old 01-24-2009, 11:47 PM
rbuswell's Avatar
Porsche Crest I'm either dense or I'm not a very good communicator
86911cab:
I think you meant 911.602.185.00. 991.602.185.00 came up blank. Would it be a big pain to have you post a picture of your engine from an angle that will help me understand? I'm thinking that those units you site, cab, are what I need for the other wires but I'm concentrating on the two units on top of the fan housing in this picture. I don't have photoshop so I can't really circle or point to the units I'm writing about. There aren't two bolts holding them on in the picture above. Nor is there a bracket for the metal screws to fasten into or some sort of metal plate on top of the holder itself. That's how the PET shows them looking and being attached anyway. Of course the PET is hand illustrated and not actual photos so I suppose it could look a lot different than the actual part.
It appears that the ones I want use the same simple bolts that hold the fan shroud in place and only one bolt per unit.
I'm pretty sure they aren't the part in the picture if the illustration in the PET means anything. Unfortunately, PP doesn't allow uploading PDF files or I could include the picture from the PET to this post.
1982 911SC
1987 924S
Old 01-25-2009, 10:58 AM
86911cab's Avatar
Rbuswell
Sorry for the confusion, the right part number is 911.602.185.00. My Mistake.
There is actually one bolt holding each holder to the fan housing. I was refering to the fan housing, and that there are 2 bolt holes in it that holds both of the holders.
Here is a close-up of the holder. Hope this helps you.
Old 01-25-2009, 04:04 PM
86911cab's Avatar
Here is a parts blow-up of that holder
Old 01-25-2009, 04:23 PM
rbuswell's Avatar
Porsche Crest Cab, that helps a ton!
The PET I have looks different than yours so mine is probably older and the illustration didn't match the part. Now I know what to buy! Thanks a ton.
1982 911SC
1987 924S
Old 01-25-2009, 04:36 PM
rfloz's Avatar
I tried searching Pelican by various names and by part number and can't find these. Are they unlisted?
Bob F.
1984 Carrera Factory Turbo-Look
Old 01-31-2009, 07:57 AM
cnielsen's Avatar
I have an extra set if you want to buy used ones. PM me for info
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 01-31-2009, 08:17 AM
rfloz's Avatar
PM sent.
Bob F.
Old 01-31-2009, 01:53 PM
rbuswell's Avatar
Porsche Crest Yes I'm interested
Used is fine with me. What do you want for them and what do you suppose shipping to 80112 (business address) would be?
1982 911SC
1987 924S
Old 02-01-2009, 08:59 AM
