DIY Brake bleeding
I'm getting ready to start the DE season(whoooohoo!) and need to bleed my brakes. Last service was in Aug. using ATE blue. 2 DE's and maybe 500miles of street driving since. For tech I need to have them blead. I've been reading thru the different threads and it seems pretty straightforward to do. I used to do it on my motorcycles and that was a breeze. I notice different ways people do it. I'm just trying to determine what I need to do it and what is the torque value on the bleed valve. Seems like a pretty easy DIY job? Doesn't seem worth it to pay a shop to perform a simple procedure.
PCA National Instructor 93 RS America (some things done to it....)(gone) 85 Carrera (gone) 06 BMW M5 (gone) "If you ain't first, your last" |
I like using the Motive Bleeder.
I have used the two person and vacuum methods inhte past and feel the pressure method is better. Gravity bleeding is ok too but I do not like to wait.
http://www.pelicanparts.com/techarticles/mult_bleed_brakes/mult_bleed_brakes.htm
Wonderful thing about this site..apart from the ability to search the archived threads, there is a nice selection of Tech Articles. The one I linked you to is in the brake section. Pretty easy job and I also recommend the pressure bleeder to avoid damaging the master cylinder. Make sure you pinch off the overflow line on the side of the reservoir (if you have that type of reservoir) or you'll have fluid all over the floor. Bleeders just need to be snug only.
Tony G 2000 Boxster S |
I second the Motive Bleeder.
It's a very simple procedure. Buy one and it'll pay for itself after it's first use.
Matt. 83 911SC 85.5 944 NA - Sold |
For DE you'll need flush not bleed
AutoBahned
garden sprayer for $10 + tubing for $1 + brake cap with hole and nipple = Motive Bleeder
if you want to save $$ |
The easiest way to fully flush, if you have ATE Blue in there, is to replace it with ATE Gold. That way, you'll be able to tell when the last of the old fluid is coming out and the new gold-colored fluid has replaced it. I also use the Motive bleeder, and I always used to forget to plug the vent line, until I attached the plug to the bleeder.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
I appreciate the advice! Sorry, I mean't flush.
I made the pressure style bleeder. With it flushing the brakes is one of the easiest things I've done. Would have been even easier if I had done what Steve suggested, flushing with a different colored brake fluid.
Jay
2002 Boxster Speed Yellow |
Get the speed bleeders sold by our host. They work great, makes it a one man job and very fast. A superb product.
1986 Mazda Rx-Vetten LS1 swap street / track car 2007 MX-5 Roadster, Cinnamon, MC STR champion (sold) 2013 Scion FR-S, MC STX champion (sold) 2002 Roush Stage 2 (traded) 1979 GP White 911SC coupe, aka "Bruce |
I too vote for the Speed Bleeders over the Motive any day. I used the Motive for about 4 years, and I've been on Speed Bleeders for the last 3. Much cleaner and simpler, IMO.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
I use a garden sprayer from Wal-mart. You just plug it onto the vent tube for the brake reservoir. Don't bleed more than a couple of oz. before refilling the reservoir so you don't put air into the lines.
-Andy
72 Carrera RS replica, Spec 911 racer |
I'm a big motive fan. I've never understood those that want to only flush with whatever is in the reservoir - if you are not very careful and let the level get too low you'll put air into the clutch or MC and then you have a real problem on your hands. Just dump a liter of fluid into the motive and flush until it is all gone. Could not be simpler and you are not always worrying about depressurizing, topping off the MC, pressurizing, etc. IMHO.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
If one does keep an eye on the M/C, the speed bleeders are quite slick. I bleed/flush at least 4 times a year, and have yet to suck any air into the system.
Throw it on the ground!
Better yet - scrap the $10 garden sprayer and connect tubing directly to your shop compressor set at 10 PSI.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
'85 RoW 911 Coupe '65 356 SC '72 BMW 2002Tii '10 Cayenne '20 Ram Longhorn |
If you use a Motive or similar pressure method, be sure to block the overflow tube...a golf tee work nicely.
Also, get out that double-jointed elbow and do the clutch slave cylinder too.
2003 996 Carrera gone but not forgotten '88Carrera '96 993 '89 951 |
Drain hose, wipe it down with a those blue shop paper towels until it is dry. Store with the lid on. Every few years I might get compelled to clean it out with brake cleaner, but I use it 4x a year so there's always new fluid flushing it out.
even though the instructions say to put fluid in the pressure bleeder, I keep mine dry and add to the reservoir. No clean up whatsoever and no need to worry about brake fluid absorbing water between flushes/bleeds.
Yup. The first thing I do to any of my cars is put speed bleeders on the first time I touch the brakes. They're so freaking easy, so freaking cheap, and they just WORK.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
