Won Won is offline
Won's Avatar
Vacuum leak - check your brake booster line
Red arrows - crimped clamps got loose, hoses moving freely over the nipples
Green arrows - cracked rubber hose
Black arrow - leak through the crimping
Blue arrow - old and hardened O-ring
It's possible to pull the assembly out by unmounting the heater blower moter and pushing it to the back of the engine bay.
The short piece of hose is 15mm ID, 22mm OD. The longer hose is 12 (11.8)mm ID, 19mm OD. They have twice the wall thickness compared to regular vacuum hose of the same ID.
Also check the brake booster vacuum hose leading from engine bay to center tunnel, as per John Walker: vacuum leak you probably didn't ever think of
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 02-06-2009, 07:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Good Call,
I found one of my clamps one day right at 3rd clamp in red.
'85 Carrera Targa
PCA/POC
Old 02-06-2009, 07:56 PM
