Vibration (front end)
I have new problem with my 930
I have replace front and rear brake rotors as well as pads. (just made 80 miles) I have some vibration at 65-75 mph speed on steering wheel. During braking from this or higher speed I have even more vibration. I have balance front wheel and result is the same. Tires are OK too. Bearings are Ok ( I checked it when replace rotors). What about running in rotors? I have made alignment as well all factory set up (without camber that I set to rear -1.5 and front -1.0) Any idea?
TET930 996 TT 2003 X50 996 GT3 2004 930 1988 black on black -fast... 944 TURBO S 1989 WHITE/BLACK # 1 944 TURBO S 1989 #2 911 S 1970 Targa /ex porsche werks car! 911 S 1969 Targa (under rebuild) |
If the rotor & pads are all you've changed, put a dial indicator on the rotors and see if you have excessive run out. A large piece of crud between the rotor and hub could mimic the "pedal wobble" of a warped rotor or cause vibration under braking.
Had a similar problem with my 86 Carrera. My steering rack was coming apart. Symptoms were some "wheel shake" aroung 60-70 mph and a lot of the same under hard braking.
86 Carrera POC Racecar 07 Cayman S 13 Tacoma TRD Sport 16 VW Sportwagen |
