Tomy's Avatar
Vibration (front end)
I have new problem with my 930
I have replace front and rear brake rotors as well as pads. (just made 80 miles)
I have some vibration at 65-75 mph speed on steering wheel.
During braking from this or higher speed I have even more vibration.
I have balance front wheel and result is the same.
Tires are OK too.
Bearings are Ok ( I checked it when replace rotors).
What about running in rotors?
I have made alignment as well all factory set up
(without camber that I set to rear -1.5 and front -1.0)
Any idea?
TET930 996 TT 2003 X50 996 GT3 2004
930 1988 black on black -fast...
944 TURBO S 1989 WHITE/BLACK # 1 944 TURBO S 1989 #2
911 S 1970 Targa /ex porsche werks car!
911 S 1969 Targa (under rebuild)
Old 02-05-2009, 03:43 PM
SteveinTO's Avatar
If the rotor & pads are all you've changed, put a dial indicator on the rotors and see if you have excessive run out. A large piece of crud between the rotor and hub could mimic the "pedal wobble" of a warped rotor or cause vibration under braking.
Old 02-05-2009, 09:51 PM
poc533's Avatar
Had a similar problem with my 86 Carrera. My steering rack was coming apart. Symptoms were some "wheel shake" aroung 60-70 mph and a lot of the same under hard braking.
86 Carrera POC Racecar
07 Cayman S
13 Tacoma TRD Sport
16 VW Sportwagen
Old 02-05-2009, 10:03 PM
