Help with wipers
I just pulled my 86 Carrera out of winter storage and the wipers will not park. They stop where ever I turn off the switch. Also the intermittent rheostat is not working. Any ideas where to start trouble shooting?
Thanks,
Bernie P
Old 03-04-2011, 07:42 AM
there is a fix for it but i suspect its the wiper switch. i just replaced mine and its fine now. does the intermittent switch work, if it doesn't then its probably the wiper switch on the stalk.
ken
87 targa
Old 03-04-2011, 08:12 AM
kodioneill's Avatar
check all fuses there is a separate power supply for the park signal.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-04-2011, 08:15 AM
na2ub's Avatar
It is the contact in the wiper switch on the steering column. Not hard to fix. As I remember, it was not too difficult to remove the switch / stalk. Then you probably only need to sand / scuff the contact for the switch and put it back. Maybe bend it if it is not making proper contact. The park feature and the intermittent feature both rely on this switch. Over time, corrosion stops it from working and it needs sanded. I did mine about 5 years ago, and it still works great.
Good luck.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 03-04-2011, 08:38 AM
RETIRED
Joe Bob's Avatar
I agree. Emory paper is your new friend....
2012 ML350 3.0 Turbo Diesel
Old 03-04-2011, 09:23 AM
I just took my wiper switch out and cleaned the contacts. The wipers work perfectly now. What grease should I use to protect the contacts before I put it back?
I live in las Vegas where the temperatures inside the car easily reach 140 in the sun. I need something that won't just run out when it gets hot. Wheel bering grease? Dielectric grease? NoLox? Recommendations ?
Thanks.
Randy
1986 Carrera Targa - sold
1987 Carrera Coupe - sold
2003 Twin Turbo - sold
964 Coupe - on the hunt
Old 09-08-2011, 10:07 PM
na2ub's Avatar
I think it will be fine, without grease, for at least another 10 years. If you want to grease it, I think dialectic grease is the only one appropriate. you only need the tinyest smear of grease to coat the contact metal. I wouldn't worry about it running, just don't put much on.
Doug
Old 09-09-2011, 09:06 AM
Lots of snow Porsche away
Does dialectic not indicate non-conductive? Seems an unusual choice for a switch contact.
Old 09-09-2011, 09:51 AM
I agree it seems counter-intuitive. The grease is displaced when the switch terminals contact so it doesn't prevent the switch from operating. The reason for using dielectric grease is to protect the terminals without introducing any compounds that could cause an electrical arc between terminals. It's probably not a big deal for these low-voltage switches but it matters when applying to ignition wires or high voltage switches.
Old 09-12-2011, 01:23 PM
