-   -   H4 bulb/fuse question (http://forums.pelicanparts.com/porsche-911-technical-forum/455764-h4-bulb-fuse-question.html)
gardoni 02-06-2009 04:04 PM
I've got a '90 964 in which the PO installed H4 headlights with 80/100w bulbs, which I just discovered when one blew out. In tracking down what happened I discovered the low beam fuses had been replaced with 15 amps. I'm going to switch back to 55/60w bulbs, so my question is should I replace the fuses with the stock amperage?
Many thanks,
-Gardoni
Seattle, WA
RSBob 02-06-2009 07:33 PM
Yes, you don't want to run higher amp fuses with lower wattage bulbs. Prepare to be rather disappointed when you lower the wattage - especially in the countryside in the dark in the rain.
