gardoni's Avatar
H4 bulb/fuse question
I've got a '90 964 in which the PO installed H4 headlights with 80/100w bulbs, which I just discovered when one blew out. In tracking down what happened I discovered the low beam fuses had been replaced with 15 amps. I'm going to switch back to 55/60w bulbs, so my question is should I replace the fuses with the stock amperage?
Many thanks,
-Gardoni
Seattle, WA
1990 Carerra 4
Old 02-06-2009, 04:04 PM
Banned but not out, yet..
RSBob's Avatar
Yes, you don't want to run higher amp fuses with lower wattage bulbs. Prepare to be rather disappointed when you lower the wattage - especially in the countryside in the dark in the rain.
Old 02-06-2009, 07:33 PM
