-   -   I'd like to see your ITB EFI set up; please. (http://forums.pelicanparts.com/porsche-911-technical-forum/455975-id-like-see-your-itb-efi-set-up-please.html)
TimT 02-08-2009 08:53 AM
Here a a few engine we built with EFI&ITBs
Bills 3.8, in this pic you can see the twin injector rails. We tuned this so at part throttle the engine is running one set of injectors, as soon as manifold pressure goes positive the second set of injector fire.
http://forums.pelicanparts.com/uploa...1234111806.jpg
Plenum removed, you can kind of make out two injectors per barrel.
http://forums.pelicanparts.com/uploa...1234111854.jpg
These are single injector ITBs with plenum
http://forums.pelicanparts.com/uploa...1234111911.jpg
3.7 na
http://forums.pelicanparts.com/uploa...1234111982.jpg
3.9 na
http://forums.pelicanparts.com/uploa...1234112012.jpg
TunersGroup 02-08-2009 09:01 AM
Originally Posted by jpahemi (Post 4471838)
I'm looking to convert my 3.2 DME to ITB fuel injection and would appreciate any pics of your system.
We are developing a custom ITB EFI setup at the moment in Sydney for my '79 SC.
All the CAD drawings are done and we are getting all the parts machined next week.
The test car for it is my 3.0 litre '79 SC, but we have sized the throttle bodies so that they will work equally well on a 3.2.
It incorporates filtration and velocity stacks / trumpets.
My company is an AEM dealer, so we will run it with the AEM Universal Engine Management System. There is a video about the AEM Universal EMS here ...
http://www.tunersgroup.com/Videos/AEM_Universal_Engine_Management_System_EMS_Video.h tml
My motor is out of my SC at the moment as we're rebuilding the 915 transmission, so we're developing the ITB EFI setup while the engine is out of the car - much easier to do on an engine stand than in the engine bay !
I'll post some photos of the setup next week once we have the parts machined.
I originally decided to develop it for my own car, but we may offer it as a kit.
- Adam
jpahemi 02-08-2009 11:22 AM
Tim:
How is the quality of the TWM bodies?
jp
Larry_Ratcliff 02-08-2009 11:25 AM
subscribing
TimT 02-08-2009 05:30 PM
TWM 3003 and 3006 series throttle bodies are a good quality ITBs.....You will not have any hardware problems using them
We have used them in a number of builds...
There are a number of other manufacturers on the market which look good as well...
Jenvey, PMO, Extrudabody, Hargett makes what looks like a really nice product... I want to use them (Hargett) on the next iteration of my own 2.2 screamer.
Cant remember the name now... but someone makes CF barrel valves which you an fit to a 911..Maybe Lumenition>?
Steve@Rennsport 02-08-2009 07:47 PM
Here is another good alternative.
http://forums.pelicanparts.com/uploa...1234151214.jpg
These have 46mm throttles but we have 50mm ones, too.
jpahemi 02-08-2009 08:06 PM
Steve:
Is that the same engine you discussed with me?
jp
Steve@Rennsport 02-08-2009 08:09 PM
Originally Posted by jpahemi (Post 4473658)
Steve:
jp
Thats one of them,...(this one is a 3.4).
911st 02-08-2009 08:13 PM
Steve, what are the pros and cons to a high butterfully/injector setup like that?
TunersGroup 02-09-2009 04:50 AM
Great looking setup there Steve. Do you manufacture those throttle bodies inhouse ?
Do you have any dyno sheets comparing that high butterfly setup to a lower butterfly setup ? I'd be very interested to see the differences on the dyno graphs.
- Adam
berettafan 02-09-2009 05:38 AM
Re. the offset dual injectors on a slide valve...i'd guess if you center a single injector over a slide valve setup you're not going to get all the fuel at part throttle.
Trog 03-10-2009 06:55 PM
http://forums.pelicanparts.com/uploa...1236736281.jpg
PMO ITB's, 26#/HR injectors, TECgt ECU, Tech Edge Wideband O2.
bug man nrg 06-14-2009 08:45 AM
ITBs
This is what we had at the PRI show 08
http://forums.pelicanparts.com/uploa...1244993672.jpg
http://forums.pelicanparts.com/uploa...1244993829.jpg
we have a lot of call after the show on this set up
http://forums.pelicanparts.com/uploa...1244994026.jpg
This is not a full engine this was just made up of part at the shop for the show
Mack
emerald performance your USA Jenvey dealer
CBRacerX 06-14-2009 09:09 AM
Subscribed. I had a TEC and TWM setup back in the 90's but had a hard time tuning it for street use. Things have come a long way on the EFI side.
PCA7GGR 06-14-2009 03:46 PM
Here's a pic of my 2.8 with TWM throttle bodies, 3.2 injectors, Haltech F10 ECU and Electromotive twin-plug ignition. Recent Mustang dyno tuning by John Holleran in Pinole (SF Bay Area) has resulted in immediate cold starting, 900rpm idle and excellent power/throttle response. Its never run better.
http://forums.pelicanparts.com/uploa...1245019563.jpg
alfaomega 07-08-2014 05:02 AM
http://forums.pelicanparts.com/uploa...1404820894.jpg
