don911's Avatar
black and blue and red RSA interior pixs
A few weeks of sore knees and the interior is finally done. Sound dampening is 4 coats of quiet car and a layer of Thermotech FR. Carpet and door panels are Appbiz. Both fit very well. A big thanks to Bob at Appbiz. Along with great products, Bob sent me some vinyl at no charge and I was able to recover the lower b-pillar trim and also fab some rear seat belt reel covers.
The while I was there projects: New window felt, blade seals and new shifter bushings. Next up are new door seals.
Here are some pixs just because.
oh, floor mats are new from Loyd's.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 09-27-2005, 09:54 PM
turbo dreaming
looks great =]
Princeton Wong
96' 993 Carrera 2...Turbo
As seen on MaydayGarage: http://goo.gl/mGmZB
In Excellence #191: http://goo.gl/BjOsn
Old 09-27-2005, 10:17 PM
Sameer's Avatar
Very neat
Speed Yellow 911 Ruf BTR Conversion
PCS Membership No: 266
Rennlist Membership No: 050315-5911
Ebony Black 2004 Jaguar XJ6
Titanium Grey 2003 Ford Focus
Old 09-27-2005, 10:19 PM
nice work Don! still leaves my car to finish!
Old 09-28-2005, 08:12 AM
curlesw's Avatar
Re: black and blue and red RSA interior pixs
Wow looks great! I wish I had gone with black when I updated my interior about two years ago...got talked out of it
The RS doors look nice.
Originally posted by don911
What kind of seat is that? Did you have it painted to match the car's color?
v/r
Wayne C.
Old 09-28-2005, 09:54 AM
looks fantastic! how much do those seats weigh? let us know how the sound dampening goes with the thermotech and quiet coat.
1980 911SC Targa 3.6L
Old 09-28-2005, 09:58 AM
kiesan's Avatar
Don you are an inspiration... looks awesome.
By the way the seat rails you gave me worked perfectly. My RSA seat now has the seat belt receiver on the correct side thanks to you.
I'll hook up with you soon to get you these other rails.
Kie in Seattle. '05 3.4 987, '76 930 DP/Kremer thing. Past p's... '91 928S4, '95 993, '82 928, '91 944S2, '92 964, '67 912/911 2.7, '72 911/3.0, '89 951, '87 951, '94 968 cab, '96 993, '87 928S4, '78 911SC targa, '79 911SC, '84 Carrera row, '75 911S, '85 Carrera targa, '84 930 RUF, '04 996 C4S.
Old 09-28-2005, 11:28 AM
don911's Avatar
Thanks everyone.
Kie, Glad the rails worked.
JonT. The seats are regular pole positions. The shells don't weigh much. A few lbs I think. I can weigh the other one tonight. The rails and side brackets weigh quite a bit though. My other brackets are AL but the rails are still beefy. Still a lot lighter than the factory seats.
Sound dampening worked pretty good. Not as quiet as before but 49lb came out of the back end. The engine noise isn't bad at all., it's the G50 tranny that is annoying.
Don
Old 09-28-2005, 11:41 AM
don that is sweet mate
submit signature here
Old 11-10-2005, 02:06 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
Don,
Sorry for the hijack, but how well does that Quiet Car stuff work? I had throught about stripping Stinky's interior to the metal, put on a coat or POR15 for protection, then dynamatting it to help reduce engine noise and such. If that Quiet Car stuff is any good, I might have to try that instead.
Any idea about how much weight four coats added? Why four coats?
Thanks! The car looks great! I hope my interior looks that good someday!
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 11-10-2005, 02:18 PM
Bill Verburg's Avatar
Looks great!
I have 2 black and blue interiors as well.
I wish that the dark blue carpet was available
Bill Verburg
Old 11-10-2005, 02:25 PM
PorscheGuy79's Avatar
Don,
Can you talk to me about how your mounted your seat so low. I have a pole position and im looking into ways to make it lower.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 11-10-2005, 02:32 PM
Send a message via AIM to NoLift911
Looks great -
I just picked up my RSA panels from Bob that worked out great. I couldn't bring my self to put holes in the panels to mount it so I used the clips along the bottom of the door - looks very clean.
Just requires a few mods to the bottom of the door and you can save a little more weight in the process by getting rid of those ridiculous mounting blocks that are tack welded into the door.
Sometimes I wonder if Porsche was really concerned about weight or just getting something accomplished.
The door panel caps could be lightened also with plastic and covered in vinyl - those thing are heavy.
-Jeff
Jeff
Old 11-10-2005, 02:53 PM
Jeff Alton's Avatar
I have a black and blue interior too, just like yours but with a roll bar and black seat back, for the time being. Tempted to try you noise reduction steps....
Nice work!
Cheers
www.turn3autosport.com
Old 11-10-2005, 06:12 PM
don911's Avatar
Thanks for the compliments!
For the quiet car question... Quiet car worked pretty well. It's noiser but fine for me. Engine noise is great, it's the tranny noise that I can't reduce.
I put 4 coats in the back end only. 4 coats to get decent thickness. They recommended multiple thin coats. I used roughly 60% of the gallon. The dried weight of a gallon is 8lbs so I figure I put in around 6lbs of paint on. The Thermotech FR weighed a couple lbs at most. I estimate with carpet, etc. I put less than 15lbs back in. 49lbs came out so that's a decent net.
The Quietcar company was a pain to work with tho. They couldn't figure out if they actually shipped the product. I tried to cancel my order. When I came home that same day, the paint just showed up. If I had to do it again, I'd use Silent Running. SR500. It sounds like a similar product, same price, same dried weight, etc..
http://www.silentrunning.us/html/sr_500.html
For the PP seat height. I didn't do anything special. The seat is mounted on a Brey Krause side mounts sitting on aftermarket sliders. The BK side mounts may be for sale if you're interested in them.
Don
Old 11-10-2005, 07:28 PM
Don, thanks for the info. I'll check out the Silent Running stuff. I want a nice car to drive, and I know I'll never be able to make it silent, but a little quieter would be nice.
Matt J.
Old 11-10-2005, 09:06 PM
don911's Avatar
Thanks Noah,
I have 40%ish of quiet car left if anyone wants it. I won't use it and it's only good for a year.
Don
Old 11-10-2005, 10:54 PM
We do have the RS carpet sets in Dark blue now, contact your Rep at pelican and have them specify blue
Robert Breshears
bob@appbiz.com
310-834-3600
Owner Appled Business Concepts
Old 11-18-2005, 01:38 PM
randywebb's Avatar
The problem is that one cannot determine how the Silent Running stuff works from their web site (http://www.silentrunning.us/html/how_it_works.html) - is amazingly uniformative. It may be a microbead encapsulated product like Quiet Coat or it may not. It apparently is not just a big clog of asphalt....
BTW - How many coats of the Quiet Coat did you apply. I think he told me 3 coats when I contacted them...
Sad they don't have their retail act together... kinda reminds of Nakamichi back when they were Nakamichi Research...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-18-2005, 02:09 PM
skinnerd's Avatar
hi Don
Looks great! Sorry for being so obtuse....but what kind of carpeting did you install. I'd like to get the same. Thanks, Doug
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 11-18-2005, 06:04 PM
