SCWDP911's Avatar
does this strut housing look bent to you?
title says it all...
[img]http://forums.pelicanparts.com/uploads14/DSCF11011234115633.jpg[/img
Shane
- 1984 928S
Old 02-08-2009, 09:56 AM
burgermeister's Avatar
I can hold a sheet of paper up to the screen, and the housing does not deviate from the straight paper edge.... so no, doesn't look bent if one ignores the optical illusion thing.
You could cut a couple V-notches in the end of a few 1' long 2x4's, clamp them to something, lay the strut housing in them, get out a dial indicator, and spin the strut housing around. That will give you a definitive answer.
The third answer is if it isn't bent more than a mm or two, why would it matter? As long as the shock fits & works and you can align the car, it ought to be OK.
Why is the metal by the spindle so shiny?
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-08-2009, 11:43 AM
UNDER CONSTRUCTION!
carrera turbo's Avatar
yes looks bent to me looks as if the spindle casing or housing has moved on the strut. but hard to tell from a pic. you can do some basic measurements tip of spindle to lower tip of strut and compare to other side. not precision but may get you started.
good luck ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 02-08-2009, 11:49 AM
SCWDP911's Avatar
That is why I was asking the question in the first place. I know my bent strut on my car looks like this one, but only after hitting the construction pylon at speed...
Here is a picture of the stock one on my car for reference...
Shane
- 1984 928S
Old 02-08-2009, 11:51 AM
SCWDP911's Avatar
Thanks Ed... have you started to defrost up there yet? Anything new on your struts?
Shane
- 1984 928S
Old 02-08-2009, 12:02 PM
AutoBahned
RWebb's Avatar
the real query may be not if the housing is bent, but is the cast metal spindle gizmo at an inappropriate angle to the housing...
Old 02-08-2009, 12:59 PM
SCWDP911's Avatar
I think I see what you are saying RWebb... I think someone told me in another thread something about an 11 degree measurement?
Shane
- 1984 928S
Old 02-08-2009, 01:03 PM
UNDER CONSTRUCTION!
yea shane
the temp is up to about 4deg today. im looking at parting this car out in early march. after the fur rondy race is over im a bit busy with race cars at this time and the car is stored out side.
but the struts are yours if you still need them.
cheers ed
Old 02-08-2009, 01:44 PM
3.2 CAB's Avatar
Shane, is the first photo one of the "new" replacement struts? Or is it your damaged one off of the car? If it is the replacement one, it appears that it is showing even more exposed metal than your old one. Good luck with it!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 02-09-2009, 07:34 AM
SCWDP911's Avatar
Hey Tony,
Yeah that first one is the pax side of the replacement set I purchased. The driver's side seems to be OK. The guy I bought them from is decent and there are no issues. I just wanted to make sure I was seeing what I thought I was seeing... Trying to decide whether to mix the set (this one is from a Carrera) or stay with 2 from the same year car. I am thinking at this point that technically it won't matter.
Shane
- 1984 928S
Old 02-09-2009, 08:37 AM
