(the shotguns)
Generic hot rod header question (caps, etc)
Was watching one of the Sunday am hot rod shows and they were showing a set of massive headers that could either be run open OR be capped and run through a longer exhaust system including a muffler.
My question is wouldn't running the open headers lean out the mixture if it was normally set for driving with the muffler? Maybe it's just the large diameter of the collector that is throwing me off but going from that massive tube to a 2" or similar exhaust that then goes through a muffler just seems like two wildly different exhaust scenarios.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
In a word, yes.
When I was running at the drag strip with my Camaro, we always ran with the full exhaust while others would run open headers. They would then wonder why their car ran like crap. Depending on the tune, some engines will respond well to freeing up exhaust but most will run worse.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
As the exhaust cools traveling from the engine rearward, one would theoretically need a smaller diameter pipe further back to keep the velocity the same.
I suspect much 'exhaust tuning' is really just loudness enhancement. If it's louder, it feels faster. Some folks of course run nitrous, which has it's own fuel enrichment circuit along with the funny gas ... that could be set up to run with open headers and the rest of the motor could be set to run with the exhaust system.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Navin Johnson
Check out Supertraps info... they have, or had some info regarding the length of the exhaust stream... and its effect on power..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
(the shotguns)
what put the quesiton in my head was my recent sport muffler conversion. in reading up on that i found several comments about the mixture leaning out when going from a 1out to a 2 out.
(the shotguns)
so then i'm thinking if the hot rod carb is tuned with mufflers on for general driving and horseplay then it must lean out when going open pipes presumably at what these ne'r do wells refer to as a speed contest. so they're running the car hardest in a leaned out condition which i thought was bad juju.
seems like without a computer reading the exhaust you only get one or the other.
Navin Johnson
I happened to revisit Supercraps page when you posted earlier..
http://www.supertrapp.com/technology/index.asp
(the shotguns)
well it seems i have correctly hypothesized something.
that this something has been known about since the beginning of time is of no consequence to my pride. neat!
