toddu's Avatar
Felt like MacGyver - 911 no start
It was a nice day here in Charlotte yesterday, so I gave the 911 a quick bath and headed off to Starbucks to do some work. I had a conference call at 2pm that I wanted to take at home, so I left Starbucks at 1.
I was first upset because a bird had s*#t on my clean car (never fails). I get in and twist the key and the car stumbles a bit. Twist it again and it cranks, but that's it. Now I'm a bit pissed. I open the lid to poke around, thinking maybe something got wet washing it (ran fine on the way over however).
Long story short, I took my con call in the car, gathered my thoughts and deduced it was the fuel pump relay. Certainly can't find one anywhere near where I was. What to do. It was a short walk over to Lowes where I bought some wire and a wire cutter/stripper - $10. Walked back to my car and fashioned up a jumper to jump pins 87A and 30 where the relay plugs in. I was home 15 minutes later!!!!
Todd
'81 SC
Old 02-11-2009, 08:03 AM
I wonder if your solution is also an accepted method for testing out a suspect red cap fuel relay?
My intermittent fuel delivery problem is hard to determine because my spare relay was acting up before I took it out and replaced it several years ago.
Old 02-11-2009, 08:14 AM
Designer King
Paulporsche's Avatar
Brings to mind a few things:
I usually carry a small rag or paper towels and a small bottle of water for those inevitable bird surprises while parked.
I also carry a couple of spare FP relays.
If you didn't have a spare you could have used one of the black ones for a short time.
Glad you got going. BTW what kind of work do you do that you go to a Starbuck's to do it?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 02-11-2009, 08:20 AM
toddu's Avatar
I had thought about stealing one of the other relays, but my fuze cover is in the garage (some work going on under the hood - removing AC), so I wasn't sure which relay wasn't critical, like a horn for example.
As far as working at Starbucks, I do IT stuff, so if I'm not at a customer site I put a few hours in at Starbucks because the 2yr old at home is too distracting .
Todd
'81 SC
Old 02-11-2009, 08:29 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Originally Posted by toddu View Post
IAs far as working at Starbucks, I do IT stuff, so if I'm not at a customer site I put a few hours in at Starbucks because the 2yr old at home is too distracting .
Todd
And it's a great place for spotting MILFS!!!
of course they aren't as distracting as a 2 YO
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 02-11-2009, 08:34 AM
