Knee Pad Removal HELP!
I am trying to remove the knee pads from my 82 SC. I cannot find any securing bolts, nuts or screws. are they stuck on? any help would be appreciated.
Mike
2012 Mercedes ML350 2011 Mercedes S550 AMG 2001 Mercedes SKL230 2001 Carrera 996 82 911SC |
There's 2 little nuts on the back of each knee pad. You need to fold yourself into a pretzel and get your head under the dash.
One of those tricky jobs where you will drop the nut and washer a few times on reinstallment.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan. “Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan. |
Almost Banned Once
Feel behind the knee pad area with your hand. You should easily find the two nuts...(10mm socket)
Work in Progress
Hey Mike.
It is easier, although not necessary, to take one of the seats out and lay on your back on the floor to do the job. Here is a picture of the knee pad removed with the bolts pointed out. Maybe that will at least give you a reference point to find them. Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
I thought it was a 8mm socket.........
Almost Banned Once
You're right... 8mm it is. My bad
Plus you need hands the size of a five year old!
David 1972 911T/S MFI Survivor |
Evil Genius
a ratcheting small 8mm box end wrench works good too.
up down up down, repeat 8,000 times per nut.
Life is a big ocean to swim in. Wag more, bark less.
Thanks, You guys are awesome
Mike
1/4in drive ratchet,6in extension,8mm socket
some of the nuts it is easier just to use a tool to crack them loose and then reach in with your fingers and undo. press on the kneepad where the stud is to take the pressure off the nut. some nuts you need the extension and some you don't. the screwdriver handle 1/4in drive is usefull for the one where the extension with ratchet is just a little to long and hits the underdash. and if you know where they are you don't have to lay under the dash. Last edited by lonewolf; 02-11-2009 at 03:05 PM.. |
I used an 8mm nut-driver. The one near the center of the dash was easy (okay, I cheated - the radio is out).
The other was not so easy. Hard to get the angle right and it got rounded off a bit. Seat out would make it easier. Man, I hate working under the dashboard.
Bob F. 1984 Carrera Factory Turbo-Look |
Schleprock
This is definitely one of those on your back jobs that is not fun. And I pity the fool who tries to take my knee pad out. One of the studs came "unglued" and spins when you try to loosen the nut...........
Kevin L '86 Carrera "Larry" |
