Iowa911's Avatar
Glass install on "My Classic Car"
Hey, I was just watching My Classic Car, and they showed the rope technique for installing windshields. I am going to be doing this in the next month or so and was kind of sweating it. Now that I have actually seen it done, I don't think it will be too tough. The episode will be on again Monday at 2am central, set your TIVOs!
Dean T
1984 Cab White/Blue
Cat bypass, B&B muffler, Steve W. Chip
1966 912 Red/Black
1963 356B --sold--
Old 02-22-2009, 06:51 AM
yup i saw it. thats how i tried to do my old jeep windsheild but the seal was a hell of alot stiffer than theirs because it was old and i couldnt do it. i had a guy come and we got it in with lots or liquid wrench and a few plastic pry bars no rope.
Old 02-22-2009, 07:02 AM
kodioneill's Avatar
i use 14 gauge insulated wire. have someone help you by applying slight pressure on the outside of the glass while you pull the wire. silicone spray on the rubber and opening work well.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-22-2009, 07:21 AM
Carrerax's Avatar
I saw it also. It is actually fairly easy to do.......now, what about that cartoon car and the LM002!!! Very cool.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 02-22-2009, 08:10 AM
Tim
Send a message via MSN to tvanbroekhoven
Did it a couple of months ago, very easy.
The choice of rope is important though
Old 02-22-2009, 08:47 AM
Talewinds's Avatar
Is this technique for removing windshields or installing them?
Old 02-22-2009, 09:32 AM
Carrerax's Avatar
Installing. To remove them just carefully cut the rubber.
Old 02-22-2009, 09:40 AM
Administrator
Jack Olsen's Avatar
The hard parts:
1) Getting a windshield out in the first place without breaking it when you want to re-use the seal.
2) Getting the window trim to sit correctly in the seal groove, at least on early cars.
Old 02-22-2009, 12:06 PM
Iowa911's Avatar
You're right, they didn't have trim to deal with, and I have heard that can be tricky. I'm just going to try and take my time.
Dean T
1984 Cab White/Blue
1966 912 Red/Black
1963 356B --sold--
Old 02-22-2009, 12:46 PM
Less brakes, more gas!
euro911sc's Avatar
The windshield was a PITA for me. I had a friend helping and we did it about 4 times before we could get the seal to seat right. I still have a spot at the upper corner drivers side that the seal falls into the frame...
My one bit of advice is use a thick bit of string/wire. This will prevent it from slipping out of the frame instead of pushing the seal edge when you pull on it.
Some people also have been known to use some plumbers putty in the corners so support the seal and help ti fit better.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-22-2009, 09:25 PM
Garage Queen
PorscheGAL's Avatar
When we replaced the seal on the Targa's rear window we used clothes line. It had a plastic coating and was thick enough to hold onto to pull. My husband pushed on the window as I pulled the rope. Just take your time. Don't jerk the rope. Carefully pull as the assistant is pushing on that area of the window.
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 02-23-2009, 03:53 AM
