Twins are more fun!
Hirschmann Antenna?
Are
James Carrera TT (3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's) |
Member 911 Anonymous
I believe they are OEM antennas.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
OEM on my car
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Detached Member
I replaced mine five years ago and it still works.
Hugh |
I replaced my '82 antenna with this exact one from e-bay. They delivered quickly and it was an easy install. It is not an exact match as the tip was different than the OEM. Hirschmann is a pretty good German company I have worked with in the past. OEM for most of the German car companies.
-Dave in Minnesota 96 C4 Cab, 85.5 944 82 SC Targa SCWDP #0023 82 928 67 912 60 T-5 B Cabrio |
i use those all the time. warranteed one last week, but they usually last a long time. who knows where they're made now.
RETIRED
The 356 weenies are all over the tip color and whatever. They used to be the bomb, now they are prolly made in China for parts made in Swaziland......
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Twins are more fun!
OK, thanks guys. I think I'll buy one next week then
I have one that I put in a couple of years ago. Works great.
Charles @ Woody's Custom Shop chiming in here. I think I already answered someones question via ebay if this is an OEM antenna. I'm sure PORSCHE has the same style antenna with a PORSCHE part # which I would refer to as an OE antenna, probably 3 to 4 times as expensive as the OEM Hirschmann antenna we sell. Available with either a black or chrome mast. I know a fellow Pelican member that use to rebuild his antenna every couple of years until he found us, he gave up the rebuild hassle and purchased a complete new unit. He's going on three years now and it is still functioning properly. I also stock a "Hirschmann Power Antenna Maintenance Kit" which consists of three antenna wipes and a tube of Hirschmann antenna grease, $12.95 plus shipping. Will certainly prolong the operation of your current power antenna. If you need a replacement Hirschmann antenna you are welcome to purchase through ebay or call us direct, 949-722-1084 or 1-877-435-6911 M-F 9-5 PST
All the best, Charles
Charles 1970 911t 1962 356 S90 1964 Safari Rally Comet Editor www.Bench-Racing.com |
Put on my '84 when I bought it 4 years ago. Both the black on the mast and the motor holding up very well.
I did wire it up directly to an after-market Alpine. Now I don't have the antenna raised when there's a CD in or my iPod hooked up--yeh, I know, a minor victory.
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
I grease the mast occasionally on the manual type
RETIRED
Insert dick joke....
