Help with a Rim
I saw this rim at a local shop. I don't know much about offsets and bolt patterns. Can someone tell me if this will fit a 911? correctly?
Old 03-05-2009, 01:33 PM
Bill Verburg's Avatar
Maybe someone can rear that but I can't.
it's an xx x18 wheel, ETxx??
alos can't tell what bolt pattern it has. You need 5x130
Bill Verburg
Old 03-05-2009, 02:16 PM
1980 911 SC
It looks like it has 5 x 114 lug pattern inscribed on one of the spokes. I believe that would fit my wifes dodge. It looks used so you might ask the shop if you can borrow it for a fitting. Then you'll know.
Life's a Beach
Old 03-05-2009, 02:18 PM
Didnt p[ost as well as I thought. Markings starting at 1:00 and going around clock wise are as follows:
18x71/2JJ
690KG
5H 11.4. 3
MANARA
DESIGNED BY
ET 4/3
100
I gather it's an 18" x 7-1/2" Rim but that is all I can figure out other than it was designed by Manara.
Old 03-05-2009, 02:23 PM
18x71/2JJ
690KG
5H 11.4. 3
MANARA
DESIGNED BY
ET 4/3
100
That won't fit a 911, 964 or 993
Bill Verburg
Old 03-05-2009, 02:38 PM
Thank you for your help.
Old 03-05-2009, 03:38 PM
chrisp's Avatar
plus, it weighs 690 kg....
'83 SC
Old 03-05-2009, 03:46 PM
Kevin Stewart's Avatar
actualy a twin bolt pattern 5x114.3 and 5x108 probably et 40, Kevin
Old 03-05-2009, 06:32 PM
