1971 Porsche carrera
Hello all I am new here and would like to say there is a lot of info here.
Here is my question, i just picked up a 1971 porsche carrera 2.2 L from an estate sale in southern california for very very cheap and would like to know the value of this classic german engineering piece of art? The car also came with an 3.0 liter spare engine. All the # match.
Thanks in advance
RC
Old 02-13-2009, 08:27 PM
efhughes3's Avatar
Excellent '71's go for about $3,000-4,000 or so.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-13-2009, 08:38 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
hmm 71 carrera?
i think you have a 911T,E,S, not sure if they made some rare carrera ive not heard of.
and these cars go for alot more than 3-4k if not a rusty hulk.
ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 02-13-2009, 08:41 PM
myfast911's Avatar
can you post some pictures please? you will get better response that way.
Old 02-13-2009, 08:42 PM
efhughes3's Avatar
ed
It was a joke reply, in response to the lack of info posted with the question.
Ed Hughes
2015 981 Cayman GTS
Old 02-13-2009, 08:49 PM
I will post some pix soon.
RC
Old 02-13-2009, 08:52 PM
Send a message via Yahoo to Larry_Ratcliff
LOL yup those old ugly long hood cars with the dated horn grills and skinny tires are a tough sale.
Old 02-13-2009, 09:11 PM
UNDER CONSTRUCTION!
yea after my post i realized that but didnt see any reason to edit as i noticed post "1" and thought the whole thing could have been a joke.
ed
Old 02-13-2009, 09:33 PM
UNDER CONSTRUCTION!
yea but there is a short nose update kit in the parts section for really cheap
yea dont forget that awfull sound of the triple throat carbs sining at your back.
yea one of use should probably have that 71 carrera
cheers ed
Old 02-13-2009, 09:39 PM
1971 Porsche:
the car is not numbers matching- no way with a 3 liter engine
the car is not a carrera. the first year of the production carrera was 1973 and it was equipped with a 2.7 liter mechanically injected engine
without LOTS of detailed pictures, no one here could give you a fair estimate of value. And even then it would be very subjective due to not being able to drive it to guage its performance and feel
good luck
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 02-14-2009, 10:24 AM
Here are some pictures. RC
Old 02-14-2009, 01:35 PM
kodioneill's Avatar
911s. not sure of the year maybe a 75, not a 71 for sure.
nice looking car.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-14-2009, 01:44 PM
Bill Verburg's Avatar
That's a turbo body kit, FWIW it looks nicely done in the pics.
the engine is some variety of CIS injected 6, w/ early heat.
Try to get a serial #, it should be on the vertical part of the block to the lower right of the cooling fan.
Bill Verburg
You could probably part it out for somewhere around 8 or 9K ...
As for early long hood value I believe it has been destroyed with that one...
Or drive it and enjoy it ... looks reasonably well done...
Old 02-14-2009, 01:47 PM
kodioneill's Avatar
how about a vin?
1982 chiffon 911sc
Old 02-14-2009, 01:53 PM
UNDER CONSTRUCTION!
it does look to be a 2.7 liter of some sort but there is no way its numbers matching even with are you sure on the 71 year, its either a up dated 71 or a 74 up car.
without a vin its hard to say. the blacked out targa bar and window trim throws me towards a carrera of 74-75, maybe someone turbo bodied a carrera and thats why they told you carrera.
im interested to here what this turns out to be.
ed
kodioneill's Avatar
the relay box looks like 75-76 or so.
need more interior pics and a shot from under the rear so you can see the bottom of the engine.
1982 chiffon 911sc
Old 02-14-2009, 01:55 PM
Car is definitely an early chassis as the dash face, guages, column and switches are all early, so most likely 71 as represented. Vin check to make sure
Nice looking car that someone spent some $$ on with the update. Mirrors are aftermarket and subjective regarding looks.
Motor is a 2.7 CIS . Would like to see the engine number and type to make sure it is an S. Green shroud means it is the 165 hp version.
Being a targa and updated early chassis means careful inspection for rust, condition and type of suspension/ brakes, transmission type (70/71 reverse pull 911 or 915 update? What is the shift pattern? 1st to bottom left and back or straight up ? )
Value? soooo dependent on condition and total menu of bits that make up the car
1970 911 Targa "ST"
Old 02-14-2009, 02:30 PM
Thank to all of you that replied, I am no expert but I a learning slowly.
I will check the vin # and post some more pix later.
RC
Old 02-14-2009, 03:05 PM
M491Cabriolet's Avatar
911e?
I wonder if it started life as a 2.2 liter 911E (based on the 6900 RPM Tachometer). I understood that the 3.0 liter engine was a spare and the 2.2 was still installed. Maybe I misread it.
Old 02-14-2009, 04:53 PM
